Ferrari F1-75
Re: Ferrari F1-75
SiLo wrote:
24 Mar 2022, 13:24
GrrG wrote:
24 Mar 2022, 12:12
Ferrari's 2022 power unit.
Are the two large tubes feeding the compressor?
Coming from the intercooler to the inlet manifold.
Jakxy
Jakxy
Re: Ferrari F1-75
gluon wrote:
24 Mar 2022, 13:38
Looks like Ferrari and Alpine are using less wing than McLaren and crucially RBR.
You never know which setup RB will end up!
Lately they usually use low df setup.
SiLo
139
Re: Ferrari F1-75
If the rumours in the paddock are true about the engine being excellent, they can run more downforce to help them in the corners.
Plus their sidepod design inherently providing lower drag overall helps.
Felipe Baby!
GrrG
86
Re: Ferrari F1-75
Scarbs split turbo
GrrG
86
Re: Ferrari F1-75
.poz
.poz
51
Re: Ferrari F1-75
Andi76 wrote:
23 Mar 2022, 20:20
In the V8 era they ahuge amount of work in modifying the airbox. And were able to increase power significantly because of that. So i think this will probably be an area teams will put a lot of effort in now.
Not with a turbo engine
Re: Ferrari F1-75
GrrG wrote:
24 Mar 2022, 15:22
Quite visibly shallower wing. Smaller AoA and camber as well.
Re: Ferrari F1-75
GrrG wrote:
24 Mar 2022, 12:12
Reverse facing compressor? The inlet pipe is very odd.
GrrG
86
Re: Ferrari F1-75
LM10
LM10
122
Re: Ferrari F1-75
GrrG wrote:
24 Mar 2022, 12:12
Strange that Ferrari is OK with presenting the PU in it's naked entirety.
GrrG
86
Re: Ferrari F1-75
wowgr8
wowgr8
29
Re: Ferrari F1-75
Vanja #66 wrote:
24 Mar 2022, 16:42
GrrG wrote:
24 Mar 2022, 15:22
Looks the same as Bahrain to me
wowgr8
wowgr8
29
Re: Ferrari F1-75
LM10 wrote:
24 Mar 2022, 17:12
I'm guessing that was taken at the Haas (or Alfa) garage, the factory team would probably be more secretive
TNTHead
Re: Ferrari F1-75
LM10 wrote:
24 Mar 2022, 17:12
GrrG wrote:
24 Mar 2022, 12:12
Isn't it true that development of the current (ICE part of the) PU's are frozen, so it doesn't matter anymore?
Emag
Emag
109
Re: Ferrari F1-75
LM10 wrote:
24 Mar 2022, 17:12
GrrG wrote:
24 Mar 2022, 12:12
Aren't power units pretty much locked until 2026? I would guess it's relatively safe to give out a bit more than usually.
Developer of F1InsightsHub
