12 more horsepower from changing seals that allow for a different oil formulation.
Nice upgrade.
And that (plus the f-duct?) resulted in the highest top speed of nearly 312 kph ...segedunum wrote:That's an impressive boost in power and is at the top end of what I would expect from gains in allowed homologation changes.
What for? Ferrari has never claimed that they could not finish the race. They're not virgin, they've got the red goddess.Holm86 wrote:I really thinks that's a load of bull sh**. Why not make a larger nitrogen tank??
I think that gaining 20 HP with that change is up there with knowing with precision the position and momentum of an electron. Seriously speaking, if they gained 20 HP with a change other teams admitted, their previous valves must have sucked BIG time.autogyro wrote:Typical Ferrari, that has ruined my season.
At least an extra 20 hp what a con.
If I was a team owner I would go ballistic.
Have you read this? --autogyro wrote:Typical Ferrari, that has ruined my season.
Ferrari had a problem. They requested permission to fix the problem. Permission was granted. What they did to their engine was shared with other engine suppliers. And I believe Scarbs said they gained 12 HP, not 20?Teams are however allowed to make changes to the their engines for reliability reasons, this applies both to resolving issues that have ‘blown up’ engines, as well as impending failures. To request a change, teams have to apply to the FIA outlining the reason for the change and the resulting changes. This information is passed around the other engine suppliers, this transparency helps to reduce excessive changes and reassures teams what their rivals might or might not be getting up to.
The constant attacks on Ferrari are a continuing source of amusement. If they were an also-ran, no one would say anything. Their position as one of the greatest teams in F1 history makes them an easy target by those who envy their success.A different PVRS set up, with different seals and revised oil formulation to aid sealing, the engine is now believed to be more powerful by some 12 horse power.
I do not envy Ferraris success. Good luck to them, all they have this year is Alonso and that is a mixed blessing. I do not like any team gaining advantage by manipulating the regulations against the principles of the sport. Fixing a pressure problem with pneumatic valves IMO technicaly, should have resulted in LESS power not more. Let us assume that the valve train on the Ferrari engine worked ok before the fix at least for guali. Fitting better seals should have extended reliability of the system at the same or maybe less power output. Improving sealing should also have reduced valve cooling not improved it. Non of the changes should have resulted in increased power AND increased strait line speed. No way.donskar wrote:Have you read this? --autogyro wrote:Typical Ferrari, that has ruined my season.
If I was a team owner I would go ballistic.Ferrari had a problem. They requested permission to fix the problem. Permission was granted. What they did to their engine was shared with other engine suppliers. And I believe Scarbs said they gained 12 HP, not 20?Teams are however allowed to make changes to the their engines for reliability reasons, this applies both to resolving issues that have ‘blown up’ engines, as well as impending failures. To request a change, teams have to apply to the FIA outlining the reason for the change and the resulting changes. This information is passed around the other engine suppliers, this transparency helps to reduce excessive changes and reassures teams what their rivals might or might not be getting up to.The constant attacks on Ferrari are a continuing source of amusement. If they were an also-ran, no one would say anything. Their position as one of the greatest teams in F1 history makes them an easy target by those who envy their success.A different PVRS set up, with different seals and revised oil formulation to aid sealing, the engine is now believed to be more powerful by some 12 horse power.
This is a technical site, perhaps you would like to explain how a reliability repair has resulted in an increase in power and top speed when it should have resulted in a reduction?Afterburner wrote:Wake up, mercedes kept improving their engine throw seasons, ferrari did it now and renault will do it in the future, no doubt about that, please stop with the "ferrari are cheating" thing, it's just envy talk.
An increase in reliability does not nessecarily equate to a reduction in power. In order to increase their reliability Ferrari are able to change certain parts of the engine. These parts will be redesigned, and during this process Ferrari will design these items not only to be more reliable but also to provide more power.autogyro wrote:This is a technical site, perhaps you would like to explain how a reliability repair has resulted in an increase in power and top speed when it should have resulted in a reduction?Afterburner wrote:Wake up, mercedes kept improving their engine throw seasons, ferrari did it now and renault will do it in the future, no doubt about that, please stop with the "ferrari are cheating" thing, it's just envy talk.
Forget all the rubbish about envy and be technical.
Wild attempt: the current valves seal the engine better than they used to. Thus, combustion might be more efficient and the compression ratio is increased. This could also allow running a more powerful mix for longer.autogyro wrote:This is a technical site, perhaps you would like to explain how a reliability repair has resulted in an increase in power and top speed when it should have resulted in a reduction?Afterburner wrote:Wake up, mercedes kept improving their engine throw seasons, ferrari did it now and renault will do it in the future, no doubt about that, please stop with the "ferrari are cheating" thing, it's just envy talk.
