This is it i believe
ScrewCaptain27 wrote: ↑31 Oct 2017, 15:08From a recent Mercedes promo video:
Bare chassis:
https://uploads.tapatalk-cdn.com/201710 ... 2c5f8a.jpg
#aerogollumturbof1 wrote: YOU SHALL NOT......STALLLLL!!!
Such an obvious picture and then they highlight some debry sticking to the wrong side of the diffuser..RZS10 wrote: ↑31 Oct 2017, 00:38https://cdn-5.motorsport.com/images/mgl ... -floor.jpg
is it me or the minimum floor problem and any car looses way too much performance? actual cars seems to have an oversensitive aero ( in few words they are all at the limit of surface stall there so a tiny problem has vast consequences)George-Jung wrote: ↑02 Nov 2017, 17:43Such an obvious picture and then they highlight some debry sticking to the wrong side of the diffuser..RZS10 wrote: ↑31 Oct 2017, 00:38https://cdn-5.motorsport.com/images/mgl ... -floor.jpg
This is it i believe![]()
I don't believe they will bring anything as in visible components . They will probably test different setups, my bet is they'll try more aggressive AOA, try and bring the nose lower with much more stiffer suspension, and bring the rear higher, just to see how the car reacts with bigger rake.
They know what the car will do with an aggressive rake - it won't work. That's why the car is the way it is. There is little they can do with the current car to help next year's, assuming a change of concept is on the cards.F1Krof wrote: ↑09 Nov 2017, 15:42I don't believe they will bring anything as in visible components . They will probably test different setups, my bet is they'll try more aggressive AOA, try and bring the nose lower with much more stiffer suspension, and bring the rear higher, just to see how the car reacts with bigger rake.
I agree completely. This is what I was trying to say earlier.PlatinumZealot wrote: ↑10 Nov 2017, 01:26Whatever they are trying it would be foolish to display it for all and sundry. It must be something that cannot be seen with the naked eye.
Can anybody explain the use of these things? Sensors, microphone?
Pressure & Temperature Sensors
