Sho'nuff, man.strad wrote:Really??
hardingfv32 wrote:
I assume our goal to downward exhaust flow. This flow also has a boundary layer and unknown flow quality coming around the side pod. A best you have 3-5 inches after the exhaust pipe opining to force the exhaust downward onto the channel floor. You are trying to push down a high velocity exhaust flow, at its highest levels, with an ambient air flow of questionable quality and strength. It is not going to happen.
Contradiction here. First, your line of reasoning is that the exhaust plume can't be pushed down to the floor of the channel, then you say that it will expand to follow the contour of the channel. Which is it?hardingfv32 wrote:
Now as you state, the exhaust plume expands and follows the contour of the channel. No need for the Coanda Effect. Now is the Coanda Effect going to augment this flow once it gets to the bottom of the channel, not clear. I would claim that the 'center axis of the exhaust flow' has not been bent in this situation.
Brian
Maybe because every team's sidepods will make some use of Coanda effect to keep flow attached around curved sections... Whereas McLaren are the only team to have an extended channel protruding past their exhaust exit, which looks like it makes clever use of the Coanda effect in a possible attempt to seal their diffuser. No need to talk about it regarding sidepods because it's common knowledge that Coanda effect (among other things i'm sure) helps teams to keep air flow attached around the sidepods.hardingfv32 wrote:
Why do we not mention Coanda Effect when discussing the flow around the side pod?
Forced exhaust gas will be high pressure though.Pup wrote:higher velocity = lower pressure
No contradiction, 'you' is the party I am speaking to.AdamCarpenter wrote: You are trying to push down a high velocity exhaust flow
Is this a common talking point in aero literature. Can you state a reference?Maybe because every team's sidepods will make some use of Coanda effect to keep flow attached around curved sections...
And in the case of exhaust flow, progressively slowing (lower) velocity means higher pressure and expansion?Pup wrote:higher velocity = lower pressure
No, I can't... That's my point... It ISN'T talked about because it isn't new or exciting with regards to a car's sidepods. Go back and re-read what Coanda effect is, then think about what will happen as air hits the curved outside edge of a sidepod.hardingfv32 wrote:
Like I said, it can expand but I don't think it does. What you've shown is what I said about rockets - they shape the bell for a particular ambient pressure and that's why when you look at the plume at liftoff it's nice and narrow but when it's way up in the atmosphere it looks like they've kicked on the afterburners. And that's rockets, not V8's, so...strad wrote:Pup...Just showing that all research I find shows the exhaust expanding.
Consider why it's slowing – because it's losing energy, this should give you a hint about whether it's expanding or contracting.hardingfv32 wrote:And in the case of exhaust flow, progressively slowing (lower) velocity means higher pressure and expansion?Pup wrote:higher velocity = lower pressure
I just finished a new intake scoop/plenum based on the principal. A couple weeks work, hope you do not prove me wrong.
And you said you did not 'need' to prove me wrong....
Brian
Maybe time for coanda, flow, pressure and other exhaust related air bending tomfoolery thread split?Owen.C93 wrote:Forced exhaust gas will be high pressure though.Pup wrote:higher velocity = lower pressure
I know what it is. It is how it is implemented that we need more 'detailed' knowledge of to know if it applies here. I brought up the side-pod example because it would seem relevant, yet you do not see it brought up in the aero literature. There is a reason we are overlooking.AdamCarpenter wrote:No, I can't... That's my point... It ISN'T talked about because it isn't new or exciting with regards to a car's sidepods.
