Mercedes AMG F1 W08 EQ Power +
spacer
spacer
Re: Mercedes AMG F1 W08 EQ Power +
you mean the two hex sockets?
3jawchuck
3jawchuck
37
spacer wrote:
10 Nov 2017, 11:36
=D>
This is a better answer than sensors or microphones. They often appear on the car for scrutineering, so probably to aid speedy removal of whatever they fix in place (edit: or as said below, to make adjustments).
F1NAC
172
new front wing at the top
f1316
f1316
84
F1Krof wrote:
10 Nov 2017, 10:39
PlatinumZealot wrote:
10 Nov 2017, 01:26
Whatever they are trying it would be foolish to display it for all and sundry. It must be something that cannot be seen with the naked eye.
I agree completely. This is what I was trying to say earlier.
Let’s not forget the big bump in the nose Mercedes showed at this very race two years ago; it was clearly (in retrospect) a nod to how they would change their suspension layout in 2016 but was clearly visible to all teams, few of which took a similar path.
scarbs
scarbs
393
matt21 wrote:
10 Nov 2017, 10:47
Can anybody explain the use of these things? Sensors, microphone?
They are two hex sockets as mentioned above. The are to tighten the two floor stays that support the diffuser. The team adjust them on the FIA flat floor to meet the flatness and deflection tests. They go into a wheel box that adjusts the length of the floor stays. I havent seen another team do it this way
matt21
86
Thanks for explanation =D>
How are the other teams doing that adjustment?
mycadcae
what is this, sensor ?
Regard,
Nik Wan, Mechanical Designer, CATIA V5/ Solidworks/Autodesk Inventor/ AutoCAD
djones
djones
I think its just tools they use to adjust something. They will pull out when finished.
3jawchuck
3jawchuck
37
mycadcae wrote:
10 Nov 2017, 13:57
https://imgr2.auto-motor-und-sport.de/M ... 129961.jpg
WTF, literally the same picture was on the previous page with the same question. Answers to that question spill over onto this page.
mycadcae
djones wrote:
10 Nov 2017, 14:13
example?..
Regard,
garyjpaterson
Not sure the validity of these claims, but seem this is what Merc are testing:
[media]https://twitter.com/SmilexTech/status/9 ... 8322865152[/media]
Translated: "Mercedes with many new features under the bonnet (steering, suspension, cooling and more)"
OO7
OO7
171
F1NAC wrote:
10 Nov 2017, 11:59
On top is the old shovel fin/cape and below is the newer version that has been used for a few races now.
scarbs
scarbs
393
matt21 wrote:
10 Nov 2017, 13:16
I haven't seen another mechanism on rivals cars. If they adjust theirs, it will be simply be via adjusting the threaded ends of the floor stays
garyjpaterson
Interesting to me who knows nothing about F1 car alignment tendencies, that how much visible toe-in there is on the front wheels on this top view from their team celebration:
Similarly it looks like a small amount of toe-out on the rear! I never would have imagined that, would have went the opposite myself (out at the front, in for the rear).
Dazed1
Dazed1
3jawchuck wrote:
10 Nov 2017, 15:50
mycadcae wrote:
10 Nov 2017, 13:57
Those round holes above there... Are they wormholes to another universe?? :?
