PreciselyBlackout wrote:Similar to the Hungary spec of the R30 RW?
http://img801.imageshack.us/img801/2048/rwbelgium2f.jpg
Is it allowed in 2014 to strech the bodywork for more rear downforce? Just like this http://www.autoguide.com/auto-news/wp-c ... 12x408.jpgBlackout wrote:Similar to the Hungary spec of the R30 RW?
*central 200mm. It got extended.shelly wrote:If you run a small delta extension in the central 150mm you could use the two vortices for downforce like strakes
ferrari design is not legal. No body work should be above a diagonal line that goes from 650mm from section AA to 300mm 50mm behind the furthest point.Borealis wrote:The Ferrari one may be legal if the bow nose forms a single section with the upper nose. Two nose supports are allowed to support the front wing as far as I'm aware. Is there a rule dictating the mounting points of the wing supports? If not could this be a legitimate get around? (as already suggested by Gary Anderson).
You mean something like this from page 71 :shelly wrote:I was looking at this image from @thewptformula on twitter;
https://pbs.twimg.com/media/BeDXWXrCUAA5mmy.jpg
representing 2011 mclaren swnowplough. I think it is a viable variation of the "bulbous bow" type - you'd have a protruding flat instead of a protruding bulb. Proven aerodynamic concept, but I am not sure it complies with the rules.
Maybe some cars will have a low wide and flat nose (like 2013 ferrari 340mm lower), with a convex tapered dome above it. have not seen any sketch of this type of nose around, it would look like a mp 4-22 nose (or the grey example above) with wide chimes at the bottom
Yes i just remembered seeing this. I also think scarbs or someone else made a sketch of a snowplough type 2014 nose. Just cant find that one.shelly wrote:Yes the "snowplough" I had in mind is like this - thank you for finding it, I had not looked well enough.
The other idea ("chimes") is a bit different in that the flat crashstructure has the pillars mounted on in it and forms the continuous section together with a shape like the mp4-22 nose
Surely that doesn't comply with the regs?Holm86 wrote:Yes i just remembered seeing this. I also think scarbs or someone else made a sketch of a snowplough type 2014 nose. Just cant find that one.shelly wrote:Yes the "snowplough" I had in mind is like this - thank you for finding it, I had not looked well enough.
**found it
https://pbs.twimg.com/media/BbXZSzGCIAApH3r.jpg:large
#aerogollumturbof1 wrote: YOU SHALL NOT......STALLLLL!!!
wuzak wrote: Surely that doesn't comply with the regs?
It was Scarbs yes.Thunders wrote:afaik it was drawn by Scarbs so it think it would be legal.
