Alfa Romeo C42
theVortexCreatorY250
Re: Alfa Romeo C42
godlameroso wrote:
18 Feb 2022, 22:50
theVortexCreatorY250 wrote:
18 Feb 2022, 22:46
godlameroso wrote:
18 Feb 2022, 21:24
I can demonstrate that it was. In regular air, flow will choke in a duct if the inlet pressure is twice the pressure in the throat. The leading edge of the floor is the inlet, notice the sharp high pressure on the outboard of the strakes. You notice the pressure differential is much lower on the top design vs the bottom one. The strakes and the center car body form a duct, the strakes raise the pressure outboard with their outwash, and create a pressure difference at the inner strake and center car body. Notice the red and the transition to blue, to me a 2:1 pressure ratio is evident. Choked flow doesn't mean no flow, it means no more upstream flow than what has been achieved. Choked flow is sonic flow and thus follows compressible flow rules. As the strakes diverge the speed increases, but the vortex breaks down before it can be accelerated by the venturi tunnel, because the mass flow is limited.
The top design has more mass flow and although choking still happens, the shockwave and expansion fan is more mild as you can see by the weaker vortex.
https://images.squarespace-cdn.com/cont ... 022+F1.png
Choking at the inlet is not desirable, choking at the throat of the venturi tunnel is, because as the top design shows, if the pressure in the diffuser is choked, then it will pull in air by the edge wing. You'll notice the pressure trace at the edge wing and the beam wing is higher than the bottom one. To me, that indicates higher mass flow, and lower pressure overall.
Downforce with these rules depends on thrusting the air under the car, well thrust = mass flow x velocity. Downvote away.
I don't understand why your going to choke at 2:1, do you have a reference? I wouldn't be surprised if the teams achieve well over 3:1.
How can you comment on this without a colour scale?
I highly doubt this CFD is density based,thus compressibility effects are neglected. Yes the bottom vortex breaks down eariler, but it still creates WAY more downforce.
https://files.catbox.moe/5679d4.jpg
P0 is reservoir pressure, in our case the inlet, and Pc is pressure measured at the throat.
Bottom floor actually is down 60 points of downforce vs the top one. Furtheremore, I have a lot of experience with choked flow in a duct, the artifacts are obvious and clear. Once again, I refer you to that youtube video I posted, you see the same choked flow phenomena.
The contour plot is clearly on Cp, not Cp0/CpT. That's formula relies on Total Pressure, so interpreting it from that contour is impossible.
In that F1 2022 video on Youtube where he actually does the CFD, he says the second case is the bottom one and that has the massive downforce gain.
I create vortices
Re: Alfa Romeo C42
Thanks for clearing that up, then I was wrong, you want choking at the inlet. Nevertheless, choking is desirable.
OO7
OO7
171
Re: Alfa Romeo C42
godlameroso wrote:
19 Feb 2022, 03:50
Something crossed my mind when I read the bold part from you. It's not for this thread/forum though. :lol:
Re: Alfa Romeo C42
OO7 wrote:
20 Feb 2022, 16:02
godlameroso wrote:
19 Feb 2022, 03:50
You can try to choke me if you want, or arm bar, or leg lock, or Deutche-suplex. I'll be at the Miami race. :evil:
the EDGE
the EDGE
68
Re: Alfa Romeo C42
godlameroso wrote:
20 Feb 2022, 18:16
OO7 wrote:
20 Feb 2022, 16:02
godlameroso wrote:
19 Feb 2022, 03:50
i'm not so sure that is what was on his mind... :wink:
OO7
OO7
171
Re: Alfa Romeo C42
godlameroso wrote:
20 Feb 2022, 18:16
OO7 wrote:
20 Feb 2022, 16:02
godlameroso wrote:
19 Feb 2022, 03:50
the EDGE wrote:
20 Feb 2022, 18:20
Yep, that wasn't on my mind, but from henceforth, I'm no longer involved in this. :lol:
wogx
Re: Alfa Romeo C42
Re: Alfa Romeo C42
wogx
Re: Alfa Romeo C42
AeroDynamic
349
Re: Alfa Romeo C42
Alfa Romeo louvres close view
Wastegate design appears to be different on the Alfa compared to the Ferrari. Ferrari and Haas both have their wastegate pipe as external as possible for as long as possible, whilst Alfa have opted for an intersection much further back
ojir19
38
Re: Alfa Romeo C42
wastegate exit, comparison with Ferrari WG
okhörosinc bandhi-bandhi, mœnoghujlu sil ɥmhpleöng, kêmphád chømu kwærthwono
AeroDynamic
349
Re: Alfa Romeo C42
ojir19
38
Re: Alfa Romeo C42
AeroDynamic
349
Re: Alfa Romeo C42
Alfa Romeo officially launched their car
tomazy
tomazy
221
Re: Alfa Romeo C42
This has a diffirent front wing, a diffirent floor and a difirent beam wing than the car in testing. Just a few changes I saw on the first glance.
