McLaren MCL60
the EDGE
the EDGE
68
Re: McLaren MCL60
FW17 wrote:
16 Feb 2023, 11:46
FittingMechanics wrote:
16 Feb 2023, 11:39
chengzhongyi2013 wrote:
15 Feb 2023, 07:43
A basic question here
Understand that the MCL60 has continued with pullrod front suspension/pushrod rear suspension
Would this suspension setup have a significant impact on mechanical grip, versus a pushrod front/rear suspension?
From my understanding of various experts - no. Both setups can have same amount of grip. Teams choose one or the other for aerodynamic reasons. Setup McLaren uses now should be better for aero. But it is possible that McLaren did not "nail" the suspension design in the first year.
I never understood this aero benefit of having a rod that is inclined from top of or from the bottom of chassis
Isn't it as simple as leaving as clear as possible path for the air to travel in the area that you need clean air, and placing the blockage in a less vulnerable place?
IMO, its not just about Air Flow or COG, there's also the best place for the chassis mounting points, to be considered too
Henk_v
Henk_v
87
Re: McLaren MCL60
Holm86 wrote:
16 Feb 2023, 12:02
... And a pullrod is under tension, where as a pushrod is under compression, so a pullrod doesn't need to be as strong, so it can be lighter and thinner.
That is True, but forces are always paired with a reaction force.
A pushrod has a tensile reaction force on the lower wishbone. A pullrod has a compressive reaction force on the upper wishbone.
Maybe, give all loads on the suspension one might be lighter than the other...
FittingMechanics
FittingMechanics
Re: McLaren MCL60
FW17 wrote:
16 Feb 2023, 11:46
Apparently by keeping it high you do not disturb critical air feeding the floor/diffusor. I am no expert but that was the talk last year when McLaren switched. No real difference in mechanical grip - only potential aero benefits.
Re: McLaren MCL60
The Front Wing looks further forward... Does this mean the Nose is longer ?
jjn9128
779
Re: McLaren MCL60
The rules are pretty prescriptive about FW leading edge position, so if that image is from the same angle and has the same lens angle they're backing off the centre span of the front wing, or the whole front wing. But they can't move it forward.
#aerogandalf
Szabi1112
Szabi1112
Re: McLaren MCL60
Hi!
Any information about test best before Bahrain Test?
Mansell89
Mansell89
Re: McLaren MCL60
Szabi1112 wrote:
18 Feb 2023, 15:50
Hi!
Think the shakedown for McLaren (filming day) on Tuesday in Bahrain, a couple of days before the test starts :)
MrGapes
34
Re: McLaren MCL60
Very excited to see the car on track today... hopefully we get a good view of that floor edge.
Swed3121
Swed3121
Re: McLaren MCL60
MrGapes wrote:
21 Feb 2023, 05:30
With this being at Bahrain, we’re likely only to see whatever McLarens social team thinks is ok, unlikely to have proper fotos until testing on Thursday.
f1rules
f1rules
621
Re: McLaren MCL60
a small river they managed to fit, not like alpine or am
Re: McLaren MCL60
Re: McLaren MCL60
Did they ditch the RB dip on the sidepod shoulders?
Re: McLaren MCL60
Blackout wrote:
21 Feb 2023, 13:41
I think i can see that the crease is still there
SBG
SBG
Re: McLaren MCL60
You can see it on the shadow on the ground. If that's the crease you meant
rgimblett
rgimblett
Re: McLaren MCL60
mclaren111 wrote:
18 Feb 2023, 13:02
To my eye, the sidepod inlet and splitter is further back, the front suspension and wing is further forward.
