I've seen your avatar on another forum, where do you live?WhiteBlue wrote:there is no way that kimi could have made it. he is on the inside of Adrian and hits left of the center. Adrian clearly brakes and turns in and only in the last moment before Kimi hits gives opposite lock to evade and go strait. for Kimi to avoid him he would have had to get his whole car width to the left and that would not have worked. Kimi was also going left already.
every single post of me shows a signature asking people politely to discuss with me if they have different opinions. so if I have failed to meet expectations in humbleness or have been too assertive about my views I apologise most defferentially to whoever harbours hurt feelings.bizadfar wrote:I've seen your avatar on another forum, where do you live?WhiteBlue wrote:there is no way that kimi could have made it. he is on the inside of Adrian and hits left of the center. Adrian clearly brakes and turns in and only in the last moment before Kimi hits gives opposite lock to evade and go strait. for Kimi to avoid him he would have had to get his whole car width to the left and that would not have worked. Kimi was also going left already.
Anyway, the replay clearly shows before contact, Adrian was slightly losing the rear on turn in which explains the opposite lock.
(insert blasphemy), the bickering about this small issue is ridiculous. Especially from you white_blue, every single post I've read from you suggests you know 100% and have no doubts. Too much confidence/cockyness can be awful u know?
I think there's a reason for that. If you look at the slow motion replay at the end of the Youtube clip, you can see that both cars are destabilised by a bump at the top of the hill. Sutil hits it and his back steps out but he just holds it. Raikkonen isn't so lucky and gets into a massive tank slapper. The Red Bull behind both of them clearly runs slightly wider, possibly to avoid the same thing? It'd be interesting to see more shots from that same angle to see what line other drivers take. But it would explain the similar crashes.yzfr7 wrote:What amazed me is that it was very similar to Coulthard's accident on Saturday, both loosing the rear under braking, the rear going to the left, exactly the same point.
since when does a driver forget, esp since engineers are always saying, warm this and that up.WhiteBlue wrote:Kimi was on cold tyres and probably forgot about it or he would not have had the problem.
Or Raikkonen just has faster reactions than Coulthard to keep it off the wall? lol...yzfr7 wrote:What amazed me is that it was very similar to Coulthard's accident on Saturday, both loosing the rear under braking, the rear going to the left, exactly the same point. Raikkonen could at least save it (from the wall), while Coulthard seemed to be in a much less brake-balanced car.
About Sutil, could it be that he saw Kimi all over the place and tried to brake late? Though with all complaints about the current mirrors I doubt that...
In which case Sutil must have faster reactions that both of them because he did keep it off the wallbizadfar wrote:
no.
Could not agree more, and applaud your courage in saying it. It is a circus, and a track that sometimes results in races that are a travesty. Spa under fire, Silverstone might disappear, and this event is sacrosanct?Frankly, Monaco, as a race track, svcks.
bizadfar wrote:... the bickering about this small issue is ridiculous. Especially from you white_blue, every single post I've read from you suggests you know 100% and have no doubts. Too much confidence/cockyness can be awful u know?
WhiteBlue wrote: ... if I have failed to meet expectations in humbleness or have been too assertive about my views I apologise most defferentially to whoever harbours hurt feelings.
bidzarfar, I answer your post because I'm a bit sensitive to being painted in dark colors publicly. if you are concerned and want to give me advise please use a PM instead of making public criticism!bizadfar wrote:... since when does a driver forget, esp since engineers are always saying, warm this and that up.![]()
btw signature is like a disclaimer, your posts are not expressed as opinions but as fact [-X ....
