Red Bull RB6
meves
meves
Re: Red Bull RB6
A good view of the red bull hub for canada
HungryHebbo
HungryHebbo
Re: Red Bull RB6
That is a gorgeous piece of engineering. The caliper mounts look tiny for what they have to deal with!
Tim.Wright
330
Re: Red Bull RB6
Man that is pornographic. Love a good hub. Thats going straight into the spank-bank
Tim
lotus7
lotus7
Re: Red Bull RB6
meves wrote:A good view of the red bull hub for canada
What is the purpose of the "missing tooth" gear on the wheel peg locating flange ?
autogyro
autogyro
Re: Red Bull RB6
I think there is a disk and calliper that goes on before the wheel.
benjabulle
benjabulle
Re: Red Bull RB6
autogyro wrote:I think there is a disk and calliper that goes on before the wheel.
not for Vettel, only the disk :mrgreen:
232
Re: Red Bull RB6
Could be for a wheel speed sensor, or something along that line of gadgetry.
BreezyRacer
BreezyRacer
Re: Red Bull RB6
On the Speed broadcast today for Q2 they closed the show with a short series shots of mechanics at work on cars. One shot was a mechanic working under the Red Bulls and low and behold, you could CLEARLY see the double diffuser inlet. If you still have it go back and pause it. Pretty interesting and it is visually simpler than I had imagined. Of course this is only one angle of it, but you can see a nice blending of the inner strakes with the inlets and the notching of the lower section to form the inlet area.
So all you aero freaks out there, go check it out! I cannot believe they got that footage.
volarchico
volarchico
Re: Red Bull RB6
BreezyRacer wrote:On the Speed broadcast today for Q2 they closed the show with a short series shots of mechanics at work on cars. One shot was a mechanic working under the Red Bulls and low and behold, you could CLEARLY see the double diffuser inlet. If you still have it go back and pause it. Pretty interesting and it is visually simpler than I had imagined. Of course this is only one angle of it, but you can see a nice blending of the inner strakes with the inlets and the notching of the lower section to form the inlet area.
Anyone get a screen capture for those of us without DVR??
lotus7
lotus7
Re: Red Bull RB6
mmm, would like to see a closeup with the disk fitted , can "picture" the caliper. No need for bigger bolts (studs) They just hold the caliper agains the flat mounting surface , which takes all the strain
raceman
Re: Red Bull RB6
It might be the catching end of a wheelgun in which teeth from wheelgun "fit" into!
raymondu999
Re: Red Bull RB6
I know it's a bit late, but I remember last race in Turkey they had low-drag endplates. Anyone have photos of THOSE?
失败者找理由,成功者找方法
autogyro
autogyro
Re: Red Bull RB6
raceman wrote:It might be the catching end of a wheelgun in which teeth from wheelgun "fit" into!
The disk has to go on first.
How about a shock and torque levelling mounting for the disk.
They have had lots of problems with the carbon disks breaking after all.
strad
117
Re: Red Bull RB6
That's exactly what it is.
Sir Stirling Moss
lotus7
lotus7
Re: Red Bull RB6
Still, how is the disk fitted ? No "normal" disk bell?
