That's not a spring, you know that?Sebp wrote:It's not the fluid that is being compressed.gilgen wrote:Hydraulic fluid per se, cannot compress, so therefore there just cannot be any spring in its use. Imagine, if hydraulic fluid could compress or spring, then we would have no JCBs etc or any other machinery using hp oil. Yes, the ancilliaries could be used to provide some give, but the oil itself, CANNOT provide any springing.
Have a look at this fine arcticle by scarbs:kilcoo316 wrote:If you have a reservoir with pressure diaphragm, you control the volume of the system. If you can do that, you can make a hydraulic "spring".
http://scarbsf1.com/blog1/2011/11/29/lo ... d-inerter/
scarbs wrote:With Mercury having a high coefficient of thermal expansion, the patent suggests using a relief valve emptying into another chamber is used to ensure the system has a constant volume of fluid.
The problem with that is that before a fluid compresses everything else around it will compress. Starting with the tyres as @Ringo rightly commented. Then the hydraulic lines and cylinders will start to expand. The amount of compression of the fluid at the same time will still be negligeable. Having hydraulic lines or cylinders expand is not an hydraulic spring. It is solid materials deforming. In doing so they will have strange spring characteristics (i.e. non-linear/degressive).ebare wrote:Hydraulic fluid cannot behave like a spring Off course it can, and without the need of a compressible fluid.
miguelalvesreis wrote:you better tell Andre Citroën about that!n smikle wrote:Hydraulics do not a good spring make. Do the maths.
Might as well u use a real spring than hydraulics, because you are gonna need humungous housings to contain a hydraulic spring. Use your God given brains people.
As you can read in my original post, i agree that the hidraulic fluid cannot work for itself as spring in a compression manner (or it won't be easy to do so), hence the use of one elastic element. Sadly i didn't make mayself clear. By "this path" i didn't mean "hidraulic spring", i meant interconnecting the four wheels, trying to emulate mechanically the electronic suspension.The problem with that is that before a fluid compresses everything else around it will compress. Starting with the tyres as @Ringo rightly commented. Then the hydraulic lines and cylinders will start to expand. The amount of compression of the fluid at the same time will still be negligeable. Having hydraulic lines or cylinders expand is not an hydraulic spring. It is solid materials deforming. In doing so they will have strange spring characteristics (i.e. non-linear/degressive).
There might be potential for tricky solutions but more likely potential for setup trouble with such characteristics especially since there are many things that will start deforming. And you have to calculate/control them all.
I'm with @Ringo on this one. I doubt anyone would go on this expedition with lots of uncertainties/risks and very vague prospects for benefits.
You are assuming that the fluid is hydraulic oil on all parts of the system? I didn't assume that at all by the article.n smikle wrote:miguelalvesreis wrote:you better tell Andre Citroën about that!n smikle wrote:Hydraulics do not a good spring make. Do the maths.
See the above posts.. Hydrualic fluid? Spring?!! Craziness. lol
