Scuderia Ferrari SF71H
Re: Scuderia Ferrari SF71H
I think that the floor sealing vortices don't run along the bottom of the floor but the top edge - they don't act like a skirt hanging down. A vortex running along the underside would be sucked inwards and be ineffective. By running the the vortex along the top side, the air around the car sees a low pressure above and below the floor and do doesn't try to flow in under the floor. The various slots etc along the floor edge are designed to maintain this equality of pressure above and below the floor edge.
Yes, the barge boards are now used to further seal the entry into the floor area, to prevent dirty air from entering. All this means that most of the air that runs under the car comes from under the driver, which is air coming from different ways around the nose and ends up under the bulkhead. Every car has various turning vanes and aero parts designed to increase suction in this area, so that more air would end up in there.
Barge boards (the vertical bits) are used to suck that low pressure zone outboard, once we reach "the safe zone" (safe from dirty air), then most of it ends up under the floor since we now have big rounded leading edges creating another low pressure zone. Final destination is diffuser of course.
For a while I was surprised that teams put the splitter so low, it didn't make any sense. Until it hit me - maybe they are using it to scoop even that low air next to the ground (no boundary layer on the ground, remember ;) ) since its mostly unused up to that point, it only passes under the centre FIA FW section.
roon
roon
412
Vanja #66 wrote:
17 Jun 2018, 20:00
Unless it's windy. 8)
AMuS
miket
miket
Found this on twitter :
But not much details.
New rear suspension ?
miket wrote:
20 Jun 2018, 12:31
https://i.imgur.com/ZmS9kD4.jpg
No it's like this since Barcelona.
Mamba
Mamba
MtthsMlw wrote:
20 Jun 2018, 13:09
miket wrote:
20 Jun 2018, 12:31
If the rumours are true (I think there was an article on motorsport.com italy), they are supposed to bring a slightly modified rear suspension to help deal with the shaved tyres.
AMuS
Ferrari had to do a legality cut on the winglet.
Is this a new position for the camera or they are going to monitor something with it?
Via AMuS
I think that camera is very often on the car on Fridays.
muramasa
muramasa
58
top: early version
bottom: new from spain (spain: only on VET car, monaco and canada: both cars)
https://www.as-web.jp/f1/381705?all
front wing at Monaco
https://www.as-web.jp/f1/376869/attachm ... a8cfd06526
Suspension in France Ph Auto Motor Und Sport vs Old Spanish GP
Spanish GP
You can see through those mid wing elements.
