Fine mesh to protect from debris probably.bhallg2k wrote:
The brake ducts appear to be turned backwards or something. Or are my eyes simply playing tricks on me?
Your right, I just realized that I posted all that in the wrong thread. BBC did a little presentation on the Williams parts for the Chinese GP. I'll move it.WilliamsF1 wrote:That says Williams F1 on it.
If you mean you can't see them...the reason is that they're hiding behind the front wing elements. You can see only the top of the duct above the wing and below the lower whisbone.bhallg2k wrote:he brake ducts appear to be turned backwards or something. Or are my eyes simply playing tricks on me?
drag reduction? huh?kalinka wrote:If you mean you can't see them...the reason is that they're hiding behind the front wing elements. You can see only the top of the duct above the wing and below the lower whisbone.bhallg2k wrote:he brake ducts appear to be turned backwards or something. Or are my eyes simply playing tricks on me?
Here's a better pic (already posted here ):
There's a smaller duct higher above, but it's not doing all the cooling, Scarbs said it's aided by that larger inlet behind the FW. It seems to me that it's a quite good drag reduction idea...
Why? Teams constantly vary brake duct shape and size, and not just because of the different cooling requirements, but also for reducing drag. It's quite a draggy thing. If the main inlet (duct) sits behind the FW, it's not directly exposed to high speed air, and that indeed can reduce drag, but sure it can interfere with air passing the FW, and causing turbulence.LotusF1 wrote:drag reduction? huh?
+1, Is it possibble that they done it intentionally to block the airflow coming from FW? I mean if they don't place a duct there, the flow could interact further back with the FEE airflow , which is coming out almost the opposite way as the FW flow...?marcush. wrote:the positioning of a brake duct is also potentially robbing front downforce ..as it blocks the flow coming from the FW
I'd say a black color on the inside and white on the outside might help just that very little bit, but I doubt it make any material difference given the total amount of air and heat in and around that area.Redmondo wrote:Does anyone know what the significance of paint color (black Renault) is on cooling?
Thermal conductivity of carbon fibre in normal to fibre axis direction is low, epoxy resins even lower, so i don't expect paint color to be of any signification.raymondu999 wrote:Just thought that one through carefully - could the dark color actually be helping to radiate the heat away? I mean, the engine would be pretty hot - it would be quite a bit hotter than the air immediately surrounding the car, I'd imagine.
