Scuderia Ferrari SF71H
LM10
LM10
122
Re: Scuderia Ferrari SF71H
I think they built back Vettel’s car to “normal” again, from the looks of it’s back, right? But I’ve just seen it on a fast lap with not so good TV quality.
If yes, then maybe they just tested for future races.
LM10 wrote:
20 Jul 2018, 12:07
That's correct.
LM10
LM10
122
Sevach wrote:
20 Jul 2018, 12:17
LM10 wrote:
20 Jul 2018, 12:07
That's correct.
Alright, thank you!
The RW Vettel tested in the first half of FP1 was first used in the post Spanish GP test.
f1analisitecnica.com
f300v10
f300v10
185
Likely testing the wing/exhaust combination as a new 'max downforce' configuration for the upcoming races in Hungary and Singapore. I doubt we will see those parts on the car again this weekend.
Fp1... new and old
Manfer
Manfer
ScrewCaptain27
577
Merc-style shield for the master cylinders:
AMuS
- Serj Tankian
LM10
LM10
122
Why do both Ferrari’s use the old version engine cover in FP2, but not the new ones from Silverstone? They used them in FP1.
Maybe because of hotter air temperature now?
roon
roon
412
Two tips but one pipe. A way to legally maximize the height of the topmost pipe, perhaps.
Oehrly
roon wrote:
20 Jul 2018, 18:08
Could be. I don't know too much about that fluid dynamics stuff but from my understanding not much exhaust gas would go through the lower pipe when there is no backpressure as it goes like 90° out of the upper one. (maybe someone who knows more about that stuff could confirm/deny that)
So probably a way to get the upper one closer to the wing.
roon wrote:
20 Jul 2018, 18:08
Indeed. Something's going on with that RW. It rises in the center when viewed from the front, but appears to bulge down when viewed from the rear. Atypical airfoil shape maybe. LP side curvature shifted rearward. May suggest a flattened central underside.
It's an extremely high camber airfoil in the middle, so from different angles it appears differently compared to outer airfoils. Seems a bit thicker as well, but that might be an optical illusion.
roon
roon
412
Vanja #66 wrote:
20 Jul 2018, 18:48
roon wrote:
20 Jul 2018, 18:08
The shape itself seems unusual. Hope I'm not falling into the reflection trap. :lol:
Manfer
Manfer
roon wrote:
20 Jul 2018, 19:11
Vanja #66 wrote:
20 Jul 2018, 18:48
roon wrote:
20 Jul 2018, 18:08
https://d2d0b2rxqzh1q5.cloudfront.net/s ... 4bdd5b.jpg
A realistic point of reference would be the height of the stiffener in the middle. You can see how the height varies from the leading to the trailing edge. The wing does seem to have a higher camber in the middle compared to the outer parts.
LM10
LM10
122
LM10 wrote:
20 Jul 2018, 16:21
No ideas, anyone? :)
