2012 Korean GP - Yeong-Am
Who will leave Korea as the championship leader?
Poll ended at 14 Oct 2012, 07:36
Alonso
42
39%
Vettel
67
61%
Total votes: 109
LHamilton
LHamilton
Re: 2012 Korean GP - Yeong-Am
The gap between Vettel and Hamilton is dued to Vettel putting in a second timed lap with more heat into the tyres. Seems that every driver struggled to improve their Soft run in their first run with the supersoft. Vettel, as most, went about 0.3s faster the first lap, then again 0.3s second time around. However, I think that Vettel still will be on pole, with Hamilton perhaps 0.2s behind.
1. VET
2. HAM
3. WEB
4. BUT
5. ALO
6. GRO
7. MAS
8. RAI
9. HUL
10. ROS
Powershift
-2
raymondu999 wrote:Good Lord. How on earth is he managing that last sector, with the first sector not being off the pace!? :wtf:
I'd have expected anyone hot in S3 to be cold in S1.
DDRS, gives downforce when you want it(S3), & drag reduction down the straights(S1), can you imagine if they link it to both the front wing and the beam wing?
Winning is the most important. Everything is consequence of that. Being second is to be the first of the ones who lose.-Ayrton Senna
raymondu999
aero expert 807 wrote:The new ddrs system makes up for any loses in s1
Powershift wrote:DDRS, gives downforce when you want it(S3), & drag reduction down the straights(S1), can you imagine if they link it to both the front wing and the beam wing?
I know what you mean, but I'm not so sure. In the past the Red Bulls have always geared their 7th gear to the DRS-limited top speed rather than to DRS-opened top speed. It will only help a tiny smidgen in top speed, and instead will help more under acceleration.
Unless Red Bull have changed setup philosophy to go for more quali pace and sacrifice race pace I assume they're doing the same now - which would mean the DDRS would only help in acceleration, not in top speed.
However we are talking tenths of a second here - Vettel was probably only 2 blinks of an eye quicker than Hamilton - so the 2/3 tenths could be due to DDRS.
失败者找理由,成功者找方法
WhiteBlue
92
It looks like Red Bull, McLaren, Ferrari is the order. So if there are no technical problems and no mistakes Vettel should be able to take the pole. Vettel 1.36, Hamilton 9.6, Alonso 44 are the odds now for pole. The only worry is Webber's engine problem, what ever it was in FP3. Please no more Renault problems for Red Bull.
Forza
238
About Webber's engine problem
Christian Horner: "There was a data issue with the engine management on Webber's car that basically didn't allow the injectors to function properly, and wouldn't let the engine fire up... there was no mechanical or electrical issue with the engine. It was just a matter of resending the codes to the engine. Unfortunately, it couldn't be rectified in the session, we couldn't do it in time.
WhiteBlue
92
Thanks for that info. Sky Germany did not tell us yet what it was.
rssh
I thinks its an agressive gearing on the Lotus for this weekend the top speed with DRS is only 311kmph . :o
WhiteBlue
92
Good start for Vettel taking P1 with .4s in front of Button and Webber.
raymondu999
Alonso and Hamilton! :wtf:
What on earth is going on!?
Good showing by the two STRs. Looks like they'll maybe repeat last year's pattern of coming good in the flyaway season?
失败者找理由,成功者找方法
zgred
WhiteBlue
92
Alonso and Hamilton made it by the skin of their teeth.
Guisson
That was Awfully Close !
The task is,not so much to see what no one has yet seenbut to think what nobody has yet thought, about that which everybody sees. Erwin Schrödinger
Chuckjr
37
wow lewis lucky senna aborted. wow
Watching F1 since 1986.
raymondu999 wrote:Alonso and Hamilton! :wtf:
Is it due to the track condition or something else has caused it?
Chuckjr
37
do you think FA was really pushing or giving just enough to make it? Hard to believe he is that slow on the reds
