I would add to your article one more aspect:turbof1 wrote:A small comparative analysis from me, between the FW37 nose and VJM08 nose: http://www.f1technical.net/features/19883. A big thanks has to go to Steven for grammar and spelling, which I admittingly did a louzy a job at!
Yes correct. I did mention at the end that other factors are at play. I might do a different article on that once more noses have been released.LookBackTime wrote:I would add to your article one more aspect:turbof1 wrote:A small comparative analysis from me, between the FW37 nose and VJM08 nose: http://www.f1technical.net/features/19883. A big thanks has to go to Steven for grammar and spelling, which I admittingly did a louzy a job at!
Williams solution allows the lower part of front wing "to behave" at full potential, so the airflow is not obstructed by the two pillars !
my 2 cents
thanks for the article, but isn't it a bit too early to compare the nose design, the FINDIA one looks too much of a mock-up (probably made from the 2014 nose)...turbof1 wrote:A small comparative analysis from me, between the FW37 nose and VJM08 nose: http://www.f1technical.net/features/19883. A big thanks has to go to Steven for grammar and spelling, which I admittingly did a louzy a job at!
It's possible, i mean the factory team had it (water intercooler) and was pretty good (understatement) with it.frosty125 wrote:I'm no engineer however Pat Symonds mentioned that they had a decent amount of weight to play with in the design of the FW37 as the FW36 was underweight and the weight limit has increased. Could they have switched to a air to water intercooler to reduce the size of the side pods? Also the larger intake below the airbox might be for cooling as well to help minimise the sidepod intake size.
very nice article ... but your comparison is not accurate, because there is a difference in front wing mounting on the nosepillars.turbof1 wrote:A small comparative analysis from me, between the FW37 nose and VJM08 nose: http://www.f1technical.net/features/19883. A big thanks has to go to Steven for grammar and spelling, which I admittingly did a louzy a job at!
No, that part is accurate. Both areas where the air goes underneath the nose is boxed in by the neutral section of the front wing, of which the height is fixed by regulations. Williams' front wing is simply put more forward (as shown on the drawings), but this on its own will not influence max air volume achievable underneath the wing. For the rest the article follows the contours of the nosepillars. Differences in mounting have been accounted for.Polemik wrote:very nice article ... but your comparison is not accurate, because there is a difference in front wing mounting on the nosepillars.turbof1 wrote:A small comparative analysis from me, between the FW37 nose and VJM08 nose: http://www.f1technical.net/features/19883. A big thanks has to go to Steven for grammar and spelling, which I admittingly did a louzy a job at!
Craig Scarborough:dren wrote:It looks like Williams is going for the most efficient, least blocking solution. The FI looks to try some interaction between the lower side of the nose and the neutral part of the wing. Either that or they didn't spend the resources to achieve a short nose like Williams did.
Or a lousy job...turbof1 wrote:A small comparative analysis from me, between the FW37 nose and VJM08 nose: http://www.f1technical.net/features/19883. A big thanks has to go to Steven for grammar and spelling, which I admittingly did a louzy a job at!
With lessons learned in 2014., all 2015 cars will very probably have smaller cooling intakes.Blackout wrote:Indeed, when you compare the sidepod cooling intakes and the turbo air intake size, this no good news for Merc's rivals...
http://www.motorsport-total.com/bilder/ ... 842169.jpg
I suggest you do a CFD analysis because there is a high pressure zone at the leading edge of the front wing that may make the assumption that the Williams brings in more air in both straight on and in yaw, moot. The guide vanes under the nose can also make up for any deficits if any.turbof1 wrote:A small comparative analysis from me, between the FW37 nose and VJM08 nose: http://www.f1technical.net/features/19883. A big thanks has to go to Steven for grammar and spelling, which I admittingly did a louzy a job at!
I don't think you have properly readed the articlePlatinumZealot wrote:I suggest you do a CFD analysis because there is a high pressure zone at the leading edge of the front wing that may make the assumption that the Williams brings in more air in both straight on and in yaw, moot. The guide vanes under the nose can also make up for any deficits if any.turbof1 wrote:A small comparative analysis from me, between the FW37 nose and VJM08 nose: http://www.f1technical.net/features/19883. A big thanks has to go to Steven for grammar and spelling, which I admittingly did a louzy a job at!
Turbo I'm sorry to say but your analysis here is far to simplistic to judge which nose works better in which conditions. The problems are:turbof1 wrote:I don't think you have properly readed the articlePlatinumZealot wrote:I suggest you do a CFD analysis because there is a high pressure zone at the leading edge of the front wing that may make the assumption that the Williams brings in more air in both straight on and in yaw, moot. The guide vanes under the nose can also make up for any deficits if any.turbof1 wrote:A small comparative analysis from me, between the FW37 nose and VJM08 nose: http://www.f1technical.net/features/19883. A big thanks has to go to Steven for grammar and spelling, which I admittingly did a louzy a job at!. My point wasn't that "Williams brings in more air both ln straight and in yaw", it was that it brought more air in a straight, but a tiny bit less when in yaw, vs the supposed 2015 FI nose.
I don't have any experience in cfd work, nor the time for the foreseeable future to learn and make cfd renders. And the issue with normal cfd work is that it's mostly steady-state, which has been proven in the past to be quite unreliable to predict real world situations. Rather, my intent here was to add the concept of yaw to air volume underneath the nose, which changes the real dimensions of the obstruction of the airflow.
