speedsense wrote:
With most of the "gas spring" calculations that been done, aren't the gas spring numbers generated from a stationary point for the piston position?
Whether at a fully open position or some distance of insertion into the shock?
At this stationary point the valving is closed on both sides of the piston (no flow through it) and if the measurement of the gas spring was taken while in this "state" the gas spring effect would be at it's highest.
As seen by 747's numbers, the larger shaft size increases the gas spring, as the volumetric displacement of the fluid by the solid rod (assuming it's solid as it is in JRZ,Moton) provides more force towards the gas.
It would stand to reason that the highest gas spring rate would be a solid rod, solid piston with ample seals and no bleed holes open.
In use (running on a car) the shock has varying fluid amounts flowing through it at the different velocities and the highest flow is at the shock's highest attainable velocity, would contribute the least amount of force/resistance (of the assembly of rod and pistons) towards the gas spring having an effect.
This would have a reduction effect on the stationary gas spring number, especially with a very high flow piston in use...
Hi Speedsense,
It seems to me, that you still have a slight misconception in regards to the gas spring in a damper - with appologize and the upmost respect.
Let´s see if this drawings help, to get my point of view across.
Imagine this to be our damper, in a stationary position, as you say all valves in the piston o closed.
As you can see, we have the same amount of pressure above and below the piston, as it´s allways the case, based on the fact, that within a fluid under pressure, the pressure is equal at any point.
As you can see, we have equal pressure acting on both sides of our piston.
The only difference is, that said pressure has a larger area to act on in one chamber (bump chamber) and as we know that F=P*A, we can see that the extension force (preload), does not result from a pressure difference from above and below the piston.
It purely results from the different surface areas on both sides of the piston.
This difference will allways be there, whatever the pressure, it does not matter if valves in the piston are open or closed.
The force would be there even if we have no piston at all.
(please see the following drawing)
We have a pressure of 20 bar inside the damper, this pressure acts all around inside the damper. And it acts on the shaft. The only place where it can´t act, is the cross section area of the shaft (PI/4*d(shaft)^2)which is outside the damper.
This part has 21 (absolute) bar on one side and ~1 bar (atmospheric pressure) on the other.
This difference * the shaft cross section area gives you the force, you feel and measure as preload on your dyno or spring tester.
If you like you can make the test for yourself, if you have access to a damper and a dyno or spring tester.
Take all the shims of the piston and test the damper, you will still measure the same gas force/preload.
You can even take the piston off, but please be careful, it will shoot the shaft straight out, when you pressurize the damper, and you will have a mess, with oil everywhere
![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
Therefore, if you really want to do this, you should clamp the damper into your dyno or spring tester first, so that it can´t blow apart -->
Zero, your loadcell, and now pressurize your damper.
The force you will read on your loadcell is P*A, give or take ~10-20 N to account for friction.
The other small glitch in your conception, is about the hollow shaft.
It does not matter, as far as the volume change is concerned, if the shaft is steel or filled with oil.
Both mediums are incompressible, so both will displace the same amount of fluid. The damper with the fluid filled shaft, has a slightliy higher oil volume to start with, is maybe a bit lighter and provides maybe a bit more cooling, as the oil can dissipate heat via the shaft now.
But as far as displacing fluid goes, and as far as our area for the gaspressure to act on is concerned, it does not matter.
Hope this makes some sense, and that the gaspressure vs. preload argument is a bit easier to understand now.
