Incidentally, I think the best argument against it is that it would probably make more sense to increase cooling capacity by venting additional cooling flow through the wheel rather than directly onto it.
taking the above at face value, and at risk of being OT, it would be interesting .....bhall II wrote:I'm still unsure what you mean by that.Tommy Cookers wrote:but we are now supposed to think the larger drivers are at a disadvantage ?
It seems that the old package is less draggier and they use it on high speed trackstpe wrote:So, the switched to the old package, right? It will be really interesting to see if they will use the "new" package in the following (slow) races.
Tantalizing idea but you would have to check how the the friction coefficient changes across tempratures. It might be curve.. it might be flat.. it might have drop offs at either end..bhall II wrote:Do you think my speculation is centered around the notion that I think current drivers are somehow unable to apply enough pedal force? It's not.
Since carbon-carbon brakes work best at high temperatures, my idea is that the vents on the right-front brake cover deliberately slow down the rate in which the disc/pads within reach optimal temperature under braking. If so, it would briefly reduce the brake's friction coefficient by a small percentage relative to the left brake, and that would make it less likely to lock up as load shifts away from it through right-hand corners.
I have no clue if this is actually feasible, because I know jack --- about tribology. But, if it is, it would allow drivers to apply more pedal force deeper into corners with lower risk of understeer. At a track like Monza, those characteristics would seem to be very advantageous.
In other words, I think it's "one-wheel thermal ABS." (But, it's probably not.)
That is illegal.atlantis wrote:One question: as per regulations, must the pressure applied to the brake pedal be distributed equally to the brakes on the same axle, in the same quantity?
Is it possible to have different brakes between, for example, the front brakes so that one brake brakes more or less than the other?
If it is possible, and if the friction coefficient (of the carbon brakes) is a well-know value, the it could be possible to adjust brake pressure differently, let one disk slide more, and the other less, to simulate some sort of "front axle differential"?.
Brake bias can only be altered front/rear not left/right.PlatinumZealot wrote:That is illegal.atlantis wrote:One question: as per regulations, must the pressure applied to the brake pedal be distributed equally to the brakes on the same axle, in the same quantity?
Does anyone have an idea what is Ferrari combustions chamber like and where is it positioned? Is this theory true?What the fuel and new combustion chamber shape combined allow is not just a bigger explosion in the combustion chamber β but a flame of greater duration, enabling the parts to be exposed to it for longer and thereby making the ignition less critical. This makes the engine more resistant to detonation β which is the chief limitation to power with this type of engine. Detonation is the phenomenon whereby the ignition becomes uncontrolled and uncoordinated with the delivery of the fuel mixture into the combustion chamber.
If it spontaneously ignites at the wrong time it can prove disastrous for the engine. The more prone the engine is to this uncontrolled ignition, the more conservatively its settings have to be to avoid it β and the less power it makes. Delay the onset of detonation with a new fuel composition and/or a better combustion chamber design and the engine can be run more aggressively, giving more power for the same fuel consumption or better fuel consumption for the same power.
This resistance to detonation is believed to be the biggest single advantage enjoyed by Mercedes over the rival Ferrari and, particularly, Renault, which is believed to be poor in this regard. This advantage compounds in the hybrid era, for the more power that is produced, the more heat that is created for the ersH to recover, giving greater electrical power too.
the sweeping last sentence is in a sweeping way - totally wrongjonaliew wrote:http://www.skysports.com/f1/news/32420/ ... cy-in-2015..... The more prone the engine is to this uncontrolled ignition, the more conservatively its settings have to be to avoid it β and the less power it makes. Delay the onset of detonation with a new fuel composition and/or a better combustion chamber design and the engine can be run more aggressively, giving more power for the same fuel consumption or better fuel consumption for the same power.
This resistance to detonation is believed to be the biggest single advantage enjoyed by Mercedes ....
The combustion chamber is the area in each cylinder bore above the cylinder - in which the combustion occurs and pushes the cylinder down. Certainly, the way you get more power on these turbos is by making the fire burn in there in a more efficient way, and using more of the fuel (since you can't inject more fuel). The theory is almost certainly correct - most of it is simply an explanation of what the (well known) phenomenon of knocking means.jonaliew wrote:Does anyone have an idea what is Ferrari combustions chamber like and where is it positioned? Is this theory true?
The thing that is responsible for more power on the crankshaft is more complete burning of the fuel, this still heats the exhaust up more as it's really all part of the same chain. Likewise the other part you ignored is, more power into the crankshaft turns into higher speed in the car which turns into higher energy recovery from the mgu-k.Tommy Cookers wrote:the sweeping last sentence is in a sweeping way - totally wrongjonaliew wrote:http://www.skysports.com/f1/news/32420/ ... cy-in-2015..... The more prone the engine is to this uncontrolled ignition, the more conservatively its settings have to be to avoid it β and the less power it makes. Delay the onset of detonation with a new fuel composition and/or a better combustion chamber design and the engine can be run more aggressively, giving more power for the same fuel consumption or better fuel consumption for the same power.
the more power that is produced (at the crankshaft) the less is the exhaust's internal energy aka heat for the ersH to recover
not even Mercedes can extract one lot of energy twice
