The point is that dyno testing cannot fully substitute track testing, regardless of how you simulate driveline vibration and resonance at the shift point. It might even be slightly different based on the driving style. All teams have the upshift oscillation issues and mappings are constant revised as peak and sustained power is modulated. This is evident in pre-season testing onboard cameras as well as anytime a new PU shakedown on track occurs. Besides, once they got the data, they were able to somewhat resolve a majority of the issue on the dyno, but as we saw with Gasly on track, it was not sufficient.Mudflap wrote: ↑11 Oct 2018, 23:21As I've explained but you seem to have missed the point is that the low tire stiffness decouples the rest of the driveline from whatever happens at the contact patch. The tire is a very effective torsional AV mount and as such for all practical purposes whatever happens at the contact patch has no effect on the torsional vibration of the driveline.ispano6 wrote: ↑11 Oct 2018, 07:52Well, actually it's not that near perfect as you purport it to be. There's nothing like simulating dynamic loads than on track testing. Also no point in bringing up McLarens operations as they were unfit to provide Honda a team environment let alone a decent gearbox in time. Imagine if Honda was still inside the Mcl33. It would have been a proper disaster and McLaren would have hidden behind the engine and Honda would be wrongfully the laughing stock.Mudflap wrote: ↑09 Oct 2018, 22:50Well actually it's not that hard, numerical solutions for torsional vibration in reciprocating engines and drivelines have been around since 1920s and have since evolved to the extent that they can capture any relevant behaviour with near perfect accuracy.
Also tire loads are not really relevant since the torsional stiffness of the tire is very low compared to that of the driveline.
So enough of this misinformation about Honda not being able to do this or that, seriously.
I missed the bits in the press about Honda being able to run dynos with a gearbox - if that is the case they should have all the tools required to diagnose and fix driveline oscillations.
The previous know how of oscillations mitigation is probably not lost as it is well documented within Honda's archives, but you will always have a new generation of engineers who will need to learn the mistakes themselves to appreciate the wisdom of prior generations and to acknowledge the prior learnings (plus back then it was a Honda gearbox I believe). Some of the Japanese engineers from the Bar Honda days still are involved with Honda or another Formula 1 team and might lend guidance or moral support. In general, this is a new formula, a new development team and a new concept.
