saviour stivala wrote: ↑07 Nov 2018, 19:27
because the technical rules stipulates a
'direct injection' as the system to be used.
This is the part I don't get. I've searched all instances of 'direct' and none apply to the fuel injector. What I do find is the following, none of which says it must be directly injected into the combustion chamber;
1.31 Fuel injector :
Any device or component that delivers fuel into an oxidiser.
5.10 Fuel systems :
5.10.1 The pressure of the fuel supplied to the fuel injectors may not exceed 500bar. Only approved parts may be used and the list of parts approved by the FIA, and the approval procedure, may be found in the Appendix to the Technical Regulations.
5.10.2 There may only be one fuel injector per cylinder and no fuel injectors are permitted upstream of the intake valves or downstream of the exhaust valves. Only approved parts may be used and the list of parts approved by the FIA, and the approval procedure, may be found in the Appendix to the Technical Regulations.
I can't seem to find the relevant 'direct injection' rule, can you tell me what paragraph of the rules specify it?
