Scuderia Ferrari SF15-T
Hail22
144
Re: Scuderia Ferrari SF15-T
RZS10 wrote:
Some special cover to preheat the brakes?
Yes seeing as the brake ducts are sealed with a temperature controlled Bosch heatgun securely attached to the housing feeding hot air around the brake drum.
Gilles Villeneuve
470
Probably to do with the set up discs they use instead of wheels to set the corner weights of the car.
Hail22
144
Suzuka - Qualifying
Gilles Villeneuve
Hail22
144
Russian GP - Sochi Wednesday
Gilles Villeneuve
Crucial_Xtreme
Crucial_Xtreme
404
New slotted brake duct vanes on Seb's car in Sochi.
Hail22
144
Russian GP - Thursday
Gilles Villeneuve
Hail22
144
Russian GP - Friday
Gilles Villeneuve
Hail22
144
Russian GP - Qualifying
Gilles Villeneuve
GoranF1
GoranF1
151
Ferrari plans to run 2016 PU on Kimi's car in USA.
Are tokens Ferrari has enough for such big changes,if not how are they allowed to run this engine this year?
http://www.formula1.com/content/fom-web ... ation.html
ferkan
ferkan
31
Engine block is 2 tokens and placement of MGUK is 2 tokens. So thats 4 tokens that they will use at Austin since they cant homologate engine that uses more tokens and therefore cannot run it at all.
f1316
f1316
84
If this is all for packaging, rather than power, then presumably Ferrari will have some accompanying bodywork for this update ? Unless it's just to verify that the engine functions correctly in this layout?
FrukostScones
163
omincorse on Ferrari PU use in USA:
https://translate.google.de/translate?s ... t=&act=url
trinidefender
trinidefender
318
Not sure if this was on the car but take a look at the front wing. Attached to the second to top element on the fixed part of the front wing seems to be a small vane thatr helps turn airflow upward.
Edit, never mind on it being new. From looking at previous pics I can see it from Singapore, didn't bother to check before that. It also seems to have a horizontal turning effect as well as an upward one.
trinidefender wrote:http://img1.auto-motor-und-sport.de/Fer ... 903208.jpg
That's the IR tyre sensor if I'm not mistaken, not a vane. This picture make that clear:
EDIT: I think your image shows only the piece on which you attach the actual sensor, so it's incomplete.
trinidefender
trinidefender
318
http://img2.auto-motor-und-sport.de/Fer ... 884817.jpg
I had thought so but in my image and in a few images from Russia it had an unmistakable concave shape as well. I'm wondering if that was originally the tyre temp sensor then Ferrari realised it had aerodynamic advantages so shaped it further.
It may be attachment point for the sensor but I don't think so as it looks to be totally smooth.
Edit: unless my eyes are seriously playing tricks on me these days.
