scarbs wrote:Yup those pictures on the wall pretty much confirm the use of coil springs. I can’t recall the last F1 car to use coil spring front suspension, I mean its use even petered out on the rear some five years ago. I guess we’d have to look at around the active era, when the rocker\damper\springs were moutned atop the chassis, so what 15 years ago..?
I can see the attractiveness of a transverse gearbox in terms of length, effectively the gearbox can be shorter, although it will be wider. With the larger fuel cell the shortness would be good to maintain wheelbase. If it weren’t for DDDs it would be Ok for aero too, as much of its bulk would be in the shadow of the engine. However the DDD needs space for the floor to rise up before the axle line, which is exactly where the transverse box sits. Of course clever design might optimise its shape for the DDD, but conceptually I’d say its not ideal.
Looking at the full car CAD image again, you can make out a wider extension to the side of the gearbox (colours browny gold in the CAD pic), you can see the upper deck of the DDD running past it. You could gain several inches of diffuser volume without this.
They won't be running coils up front. The packaging benefits of torsion bars are so well known to the entire racing community and packaging is so important in F1. Yes I saw the picture on the wall but I just don't believe they'll run front coils.How can you tell the bars aren't in the middle of bellcrank.
