Reca are we talking the same class? FIA GT1 or GT2?Reca wrote:If we really have to trust them (do you exclude it was just a polite answer to a fan ?), Sauber until a couple of years ago already had two vertical plates, on the sides of the tub, behind the wing, the keels. Maybe they just attached the horizontal mounts to the keel or to a prolongation of the keel on the nosecone.ZE.FT wrote: Anyway we have to trust Saubers aero departments statement as mentioned that they have already tried drop plates which were behind the FW but found out that they did not add downforce.
DON'T KNOW HOW TO INTER QUOTE-JUST PUT IN HERE![]()
Also had the same idea with the two plates attaching to the twin keel,but on the other hand thought THIS would have increased the structural problems indeed.
With trusting Sauber I did not exclude a polite answer to a fan but tried to say I do not have an argument against qualified personal of
a multi million USD wind tunnel team.And also said in previous reply
'unless Sauber shows up with such vertical plates' which includes a lot of
possibilities.
FIA GT rules on the rear wing does specify the dimensions of a box, the rear wing assembly (that includes, wing, endplates and vertical supports) must be contained in that box, and it’s required that the box doesn’t protrude beyond the rearmost point of the car.ZE.FT wrote: Not so sure about 'the rules do not allow bodywork behind the rear edge of the car' for FIA/GT class.if you meant so.You will have noticed the huge diffuser dimensions which are well behind the rear edge of the cars.
I just have checked the regulations for the GT1 and GT2 classes but was unable to find an explanation for the massive diffuser rear edge which certainly is well behind the rear edge of the cars (bumper).
Can you interpret the 3.6 better than I can do it?
Or do I have to search somewhere else?
