That is exactly what I meant, only in different words. I'm glad that it wasn't misunderstood.Just_a_fan wrote:... But the idea of this device, if I've understood it correctly, is to fool the air by mimicing the large radius required at the entry of the a traditional ground effect system. So you need to encourage air to flow down under the leading edge of the sidepod...
It is not the secondary floor, just the extension of default floor. The elements on top of it are not another floor, they are part of the bodywork, and below each of them there is a flat floor as FIA regs. impose (there is no bodywork on top of any hole).hardingfv32 wrote:What rule controls the area that you are proposing to use?
Can the secondary floor actually be expanded forward and have holes in it?
Brian
I made simple triangular shaped elements having in mind the simplicity. I agree that perhaps lift can be generated with such shape, so if that is the case, this comes as logical:
I guess L shaped elements as shown on second pic would cause turbulence, but I can't tell if it would be good or bad one.
Thank you all for the replies and observations, I had to write this reply in a rush, and I apologize for shortness.
