Ok, no one came with a reply, so I made just a quick 3D sketch, just a visual hint of my idea and principle, without exact shape, position or dimensions. Consider it as rough sketch.
I was wondering if having transverse apertures on the floor over-hanged in front of the sidepods, could bring more air under the floor, if the space between the apertures would have stepped snorkels above, which would direct the air into those transverse apertures and below the floor.
Think of it as artificial front end of ground effect airfoil. Diffuser at the rear already does what rear-end of ground effect airfoil is expected, but feeding it with enough air to create similar amount of Venturi effect below the car as in ground effect seasons, became almost impossible after 1982 ban, and flat floor regulations.
Since I'm not aerodynamicist, I've made only a simple model, to visually present the idea to those who know more about than me, or are professionals.
section plane
section plane
