+1stefan_ wrote:Frankly, I think Alonso deserves the title - his team doesn't.
Argh, why do people still not get this. An engine is not thrown away because another is used. Just because Hamilton used his 8th engine 6 races ago, does not mean he's used the same engine 6 races running. Instead, engines are assigned a set of (usually 3) races that they must be used for. Often this means that different engines will be used for several races running, and that then the same set of engines will be rotated in again for another set of races. None of the top drivers have used a 9th engine yet, none of them have indicated that they might need to.Red Schneider wrote:Just curious how he's doing engine wise. I can't recall whether he got a fresh one in Abu Dhabi. He's either on his eighth or ninth, right?
That isn't much of a question. He will handle the pressure exactly the same way he dealt with it after his engine failure in Korea 2010. Ignore everything around him and try to win every race. That is what he did this year as well. Why should anything change? Regarding the engine they are entitled to use another engine. Remember, this is the last race. All engines can be selected that have been used before.JimClarkFan wrote:It will be interesting to see how Vettel handles the pressure in Brazil, he has never went into a final race in the lead! Also Vettel is on his last engine, and they have that alternator problem still lingering.... looking forward to this.
Actually they may not rotate an engine in as you put it unless it is for Friday practise or the last race.beelsebob wrote:An engine is not thrown away because another is used ... engines are assigned a set of (usually 3) races that they must be used for. Often this means that different engines will be used for several races running, and that then the same set of engines will be rotated in again for another set of races.
