Ferrari F138
Forza
238
Re: Ferrari F138
kris
kris
Re: Ferrari F138
vowdy wrote:Interesting rear wing endplate indeed.
They seem to have extended the vertical gills at the bottom of the RW right to the top this year.
gibells
gibells
Re: Ferrari F138
FrukostScones wrote:
gibells wrote:Scarbs is saying it's a modesty panel, but I'm not so sure. Look at how much is missing underneath the nose.
@scarbsF1 'Ferrari F138: New nose vane layout and modesty panel'
it has to be a modesty panel, otherwise illegally high
Afaik, the height of the tub is limited, and the height of the tip is limited. How they choose to get there is there business, except that the nose must be strong enough to pass safety tests.
bhall
bhall
244
Re: Ferrari F138
Looks like the car will feature a passive F-duct ("VD"). If they work as intended, the vanes along the trailing edge of the rear wing end plates should function like a sort of diffuser. That will help draw out air vented from the jet, which should help "stall" the main plane quickly and uniformly when DRS is deployed.
EDIT: Could increase downforce, too, if they help to move air under the wing more efficiently.
Or they could be can-openers; I don't know.
(Interesting that the team edited them out of the overhead shot.)
Lorenzo_Bandini
Lorenzo_Bandini
Re: Ferrari F138
http://www.caranddriverthef1.com/formul ... 17-ferrari
The nose is very high, and the sidepost shape is the same as last year
FrukostScones
163
Re: Ferrari F138
business of modesty panel
Forza
238
Re: Ferrari F138
via AMUS
muelte
muelte
Re: Ferrari F138
There seems to be some kind of vertical strakes in the top of the difusser, a bit like RB8, or am I wrong? I see two of them beside the brake duct in the picture.
Re: Ferrari F138
They used the same chassis as last year. The sidepods are canada spec.
painkiller
painkiller
Re: Ferrari F138
Tail and Gearbox looks Williams-like... nice...
Huntresa
Huntresa
Re: Ferrari F138
Ofc its a modesty panel, otherwise it would be a step, since the nost cant be higher then the max 55.
FW17
171
Re: Ferrari F138
A lot straighter rear wishbone in comparison to Mclaren
Huntresa
Huntresa
Re: Ferrari F138
Forza wrote:Image
via AMUS
If those tyres and markings are the exact same size and in the exact same position in both pics it looks like ferrari has gained some space under the nose, look where the underside of the nose comes out from the tyre in relation to the long yellow stripe on the tyre.
Could this be modesty panel trick with gaining space under the nose? Not saying it is but it does look like more space under the nose and they were pretty much on the limit of the rules last year i assume so :P
Huntresa
Huntresa
Re: Ferrari F138
Dunno if this is correct but im trying to show what im seeing
The red line represents the underside of the nose in relation to the yellow stripe, seems to be higher up on the new car, might be wrong who knows.
Gerhardsa
Re: Ferrari F138
Most Definetaly a Modesty Panel.
