The bargeboards are moving forward 150mm for 2019, does that mean that the part shown is moving 150mm away from the floor, or that it's going to be 150mm longer and closer to the front wheels?
If there's more surface area where I have painted, then there's huge scope there for development. Whoever gets this area right will have a big advantage.
If my interpretation is correct body work will be allowed where I have painted according to
3.4.4 Exclusion volume around the front wheels
In plan view, there must be no bodywork in the area enclosed by the intersection of the
following lines:
a) A longitudinal line parallel to and 1000mm from the car centre plane.
b) A transverse line 450mm forward of the front wheel centre plane.
c) A diagonal line running rearwards and outwards, from a point 875mm forward of the
front wheel centre line and 250mm from the car centre plane, at an angle of 28° to the
car centre plane.
d) A transverse line 875mm forward of the front wheel centre plane.
e) A longitudinal line parallel to and 165mm from the car centre plane.
f) A diagonal line running forwards and inwards, from a point 430mm rearward of the
front wheel centre line and 240mm from the car centre plane, at an angle of 4.5° to the
car centre plane.
g) A diagonal line from 430mm rearward of the front wheel centre line and 240mm from
the car centre plane to 550mm forward of the plane C-C and 1000mm from the car
centre plane.
3.5.6 Bargeboard height
No bodywork which, in plan view, is in the area enclosed by the intersection of the following
lines may be more than 350mm above the reference plane :
a) A longitudinal line parallel to and 800mm from the car centre plane.
b) A diagonal line running rearwards and outwards, from a point 430mm rearward of the
car centre plane.
c) A transverse line 430mm rearward of the front wheel centre plane.
d) A line running through a point 625mm forward of the plane C-C and 320mm from the
car centre plane, running parallel to the diagonal line defined in Article 3.5.5(c).
Also, that upper wing in the 1st picture seems to be banned by 3.5.5.
3.5.5 Exclusion volume ahead of the sidepods
d) A diagonal line running rearwards and outwards, from a point 625mm forward of the
plane C-C and 320mm from the car centre plane, at an angle of 75° to the car centre
plane.
So in conclusion, according to the rules you have complete freedom in the painted red area as long as it doesn't violate the height box. This is huge in my opinion.
