Ground effect aero will always have some form of bouncing. I don't expect any car to completely eliminate it.
Indeed. As much as they could with the push rodBlackout wrote: ↑22 Feb 2023, 20:43Very RB18 front suspension layout
https://motorsport.nextgen-auto.com/pho ... ev/022.jpg
No I don’t think that’s separation. The floor edge wing will affect the air upstream as it’s showing right there. Without CFD it’s hard to see if that’s intended. They might be turning the air to induce vorticityorganic wrote: ↑23 Feb 2023, 14:37https://i.imgur.com/GKkBCPM.png
https://i.imgur.com/lqu6SQi.png
https://i.imgur.com/win7AqK.png
Are they having separation before the air gets to their floor edge wing?
That makes more sense to me101FlyingDutchman wrote: ↑23 Feb 2023, 15:10No I don’t think that’s separation. The floor edge wing will affect the air upstream as it’s showing right there. Without CFD it’s hard to see if that’s intended. They might be turning the air to induce vorticityorganic wrote: ↑23 Feb 2023, 14:37https://i.imgur.com/GKkBCPM.png
My guess is that there is a region of low pressure around the sidepod undercut (due to the curved geometry, think an airfoil surface turned on it's side). The air around the side of the upper sidepod is being sucked down into this lower pressure region.organic wrote: ↑25 Feb 2023, 14:43https://i.imgur.com/AATbWRs.png
What is causing so much downwash on the side of the sidepod?
look at the top of the mirror coverorganic wrote: ↑25 Feb 2023, 14:43https://i.imgur.com/AATbWRs.png
Someone should tell all those Predators in invisible mode to look left and right before crossing the street.organic wrote: ↑23 Feb 2023, 14:37https://i.imgur.com/GKkBCPM.png
