yes or no...you could possibly use the area obove the splitter to position the front dampers and springs it would not be that much different to what RedBull is doing with their rear pullrod arrangement....?possibly one area you could shift significant masses closer to the CoG.of course with fixed weight distribution your scope has to be to move the parts with higher specific weight as low as possible ,which is not done at this time at the front.(v-section tub =high monted rack ,pushrod =high monted torsionbars and rockers).wesley123 wrote:such an device wouldnt even work anymore on current F1 cars, the nose is simply too high to create the desired pick up points, with thelowest allowed nose these points would even be too high(the BGP001 was on the lowest allowed point), thus an pushrod would be the way to go.
