So I was looking at the 99T and MP4-5's front suspension and what I don't get it how the pushrod pushes against the shock absorber
pic found at forums.vwvortex.com/showthread.php?3438832/page64
It goes from the lower part of the chassis to the upper part of the upright
So if the wheel goes up, to me it seems like it would pull the shock absorber rather than push against it.
However, I do get how the pushrods work on a 641
The wheel goes up, causing the pushrod to push against the shock; makes sense
But, I don't get the setup used in the MP4-5
Can someone explain?
