But in Scotland? Because it seems every country and certain groups in each country all had their own definition of what the difference was.
Perhaps he was the first to actually pen down his definition?
turbof1 wrote:I wouldn't call hills in the Ardens "mountains". Just big hills. But you are right, it was a forced situation.
That's short of a traditional 3,000ft mountain from a UK perspective, but we have to remember this is Belgium. It's a generally low level country so perhaps the Ardennes are vertiginous for their context?wiki wrote:mountains averaging around 350–400 m (1,148–1,640 ft) in height but rising to over 694 m (2,276 ft)
We have a sense of the world; it isn't like that we don't realise what is standing in Nepal, so we aren't vertiginous about our ehmm... "mole dig-ups". Usually the trees are higher then the hills.richard_leeds wrote:turbof1 wrote:I wouldn't call hills in the Ardens "mountains". Just big hills. But you are right, it was a forced situation.
Meanwhile in Nepal they'd be wondering why we bother with 3,000ft pimples.
I'm not sure I'd agree. Singapore Sling (which my friend, a safety marshall for the past 3 events, plus this one, says will be removed for this year) has 3 corners, and 2 inflection points (by inflection I assume you mean the points where you move the steering wheel past 0-lock) but I'd still call that a chicane.beelsebob wrote:For me it's clear that both Les Combes and fanges are chicaines for a simple reason – the curve of the racing line through the corner has only one inflection point in the centre. An S is taken with two inflection points.
You're right – though that's rather a special case – it's rather two chicaines smushed together.raymondu999 wrote:I'm not sure I'd agree. Singapore Sling (which my friend, a safety marshall for the past 3 events, plus this one, says will be removed for this year) has 3 corners, and 2 inflection points (by inflection I assume you mean the points where you move the steering wheel past 0-lock) but I'd still call that a chicane.beelsebob wrote:For me it's clear that both Les Combes and fanges are chicaines for a simple reason – the curve of the racing line through the corner has only one inflection point in the centre. An S is taken with two inflection points.
I don't like this definition because it admits things like the Ses at sazuka or maggots/beckets/chappel at Silverstone, which are clearly not chicanes.IMO chicane is a matter of line and not a matter of apex speed. If the entry of one is connected to the exit of the previous, in the opposite direction, I'd call it a chicane. For example Abu Dhabi 2, 3, 4 would be an example. Of course then that raises a question about the drivers who straighten their steering for a split second between chicanes, because then the line effectively isn't connected
http://en.wikipedia.org/wiki/Vaalserbergrichard_leeds wrote:turbof1 wrote:I wouldn't call hills in the Ardens "mountains". Just big hills. But you are right, it was a forced situation.
Not angle of the wheel - angle of the car. ie bearing of the second corner, minus bearing of the first. Take the bearings at the apex.richard_leeds wrote:Do you mean the angle of the wheel? That'll be a function of radius of the racing line. I guess we're saying the same thing?
The angle rotated will be the same for fast or slow bends. A sweeping 45 degree bend is the same angle as a tight 45 degree bend.
You mean the era where overtaking was impossible because of the aero induced terminal understeer you got when you drove in the wake of another car?Hail22 wrote:One could only dream that this era returned to Formula 1 (V10 Naturally aspirated engines that is) with reduction in aero...
