FIA brings in noise engineers for test...
http://www.autosport.com/news/report.php/id/113945
Actually you will get more horsepower form the turbocharger with less back-pressure.mantikos wrote:Rushman wrote:http://twitter.com/MercedesAMGF1/status ... 4491452416
Why they chose a simple funnel-shaped, but not curved shape of the megaphone?
Like this:
http://www.onemetal.com/wp-content/uplo ... aphone.jpg
Due to significant backpressure loss is my guess - the megaphone type exhausts are used to draw heat out of the engine and exhaust as well as reduce backpressure when used on motorcycles...so I assuming that would negatively impact engine performance.
So in other words this will never happen. Teams can never agree on anything let alone saving the sport.Furthermore, the kind of exhaust tweak that Mercedes is trying is not allowed under the current regulations, so a rule-change would be needed if it was going to be raced.
This would require unanimous support from the teams so it could be put to the FIA's World Motor Sport Council.
If that is a real image and not photoshopped then Mercedes is taking the p%&*.
#aerogollumturbof1 wrote: YOU SHALL NOT......STALLLLL!!!
It does look unreal yes. I thought it was PS at first.Blaze1 wrote:If that is a real image and not photoshopped then Mercedes is taking the p%&*.![]()
They mentioned there was another alternative and perhaps what we are seeing is Mercedes trying to steer the F.I.A to the more complex alternative.
The trumpet is 200mm i diameter. So it takes up much of the space avalible for the monkeyseat in the 200mm exclusion aera. So you cant cover it up like those exhaust tips we have now.Thunders wrote:Wow that looks .... extreme. But bear in Mind there is Bodywork and a Monkey Seat missing that before covered a lot of the Exhaust. So IF that solution goes through the Bodywork will cover much of it.
But Simulation Expert Peter Schöggl said yesterday there are 6 or 7 more Soultions in the making. This is just the easiest one to pull of in a short Timeframe.
The "old" exhaust diameter was 150mm. The trumpet tapers out to 200mm. So you cant cover it with a monkey seat. You can place one in front of it but not cover it.Thunders wrote:Isn't the Trupet 150mm diameter?
Edit: Of Course it takes more Room but the Teams will find a way to place a Monkey Seat there.
grrr... surely a professional journalist should know how to use an apostrophe? Oh, it's Sky.
