Red Bull RB20
Mattchu
Re: Red Bull RB20
BorisTheBlade wrote:
15 Feb 2024, 22:04
I actually thought the little tag said "Remove before fun" :)
Even if this the real (which I doubt) layout of the intakes it`s far away from what Merc brought. The car still has wide sidepods with an undercut, water slide. I just don`t see how the airflow would get to the rads efficiantly!
Venturiation
Venturiation
98
Re: Red Bull RB20
Luscion wrote:
15 Feb 2024, 22:10
KimiRai wrote:
15 Feb 2024, 22:06
https://i.imgur.com/6Y5V2r3.jpeg
Seems like they are indeed vertical inlets, Tobi Gruner has a pic showing them as well
Yes this is it
SICK AL SPEEDSHOP
Re: Red Bull RB20
here it looks a bit like on the W15 imo, just flip the lips..
Re: Red Bull RB20
chrstphrln wrote:
15 Feb 2024, 22:18
SICK AL SPEEDSHOP wrote:
15 Feb 2024, 22:07
if you scroll down you can see an animation without intakes like on the pictures here and if you scroll down a bit more you can see W15 style intakes on the sidepods
https://www.redbullracing.com/int-en/
If you play with the 360 ​​degree view, you can see that there is no vertical inlet, just a small step and structural change in the monocoque.
And you can see the air inlets exactly where they make sense: on the front of the side pods, narrow and high up.
So, no W15 style visible.
You can see it nicely in the AR mode for what it's worth
Apexseal157
Re: Red Bull RB20
Venturiation wrote:
15 Feb 2024, 22:20
Luscion wrote:
15 Feb 2024, 22:10
KimiRai wrote:
15 Feb 2024, 22:06
Yes this is it
i think it's an s-duct not the main cooling inlet
Venturiation
Venturiation
98
Re: Red Bull RB20
Luscion wrote:
15 Feb 2024, 22:10
KimiRai wrote:
15 Feb 2024, 22:06
It looks real because we can see the bolts
levidrugi
levidrugi
Re: Red Bull RB20
kfrantzios wrote:
15 Feb 2024, 22:16
https://i.postimg.cc/9QHKCJhk/rb20inlets.png
There they are... if the model is correct...
Actually you can modify the renderer.
1. visit the page: https://www.redbullracing.com/int-en/cars/rb20/
2. hit F12
3. find the <model-viewer html element (or search for min-camera-orbit=)
4. change its value to min-camera-orbit="auto 124deg 28deg"
5. you can now see under the car
Re: Red Bull RB20
The problem is there are two different inlet styles showing. We are none the wiser.
The floor is completely fake on the render. Why believe anything?
Venturiation
Venturiation
98
Re: Red Bull RB20
Apexseal157
Re: Red Bull RB20
levidrugi wrote:
15 Feb 2024, 22:23
kfrantzios wrote:
15 Feb 2024, 22:16
2. hit F12
https://ibb.co/x5hbycg
https://ibb.co/0XKtNPM
an there you are thats the inlet it just makes the most sense. that vertical slot could be an s-duct but i dont see how it would be big enough to provide suffecent cooling
Re: Red Bull RB20
It's much easier to "fake" a cgi model than the real deal
dialtone
dialtone
118
Re: Red Bull RB20
Apexseal157 wrote:
Venturiation wrote:
15 Feb 2024, 22:20
Luscion wrote:
15 Feb 2024, 22:10
Yes this is it
Where is the outlet of the s-duct?
vorticism
323
Re: Red Bull RB20
If non-representative, it would not be the first time they do, essentially, a livery reveal--in '22 the reveal consisted something resembling a standard FIA '22 concept model with RB livery. This time around there is correlation to photographs so I wouldn't rule it out as at least partly authentic, which is pretty common across all teams pre-season.
In which case, they could have a faucet shaped inlet. See below.
Edit: looks like levidrugi beat me to the punch by a few minutes.
𓄀
Emag
Emag
80
Re: Red Bull RB20
15 Feb 2024, 22:21
https://img.redbull.com/images/c_fill,w ... alityimage
The floor edge is creating the illusion of a lower lip from this angle. It is not like the W15
Chmielinski
Chmielinski
Re: Red Bull RB20
MtthsMlw wrote:
15 Feb 2024, 22:25
I don't get why they'd put fake inlets on the 3D model if they could just pretend there's no inlets like on the launch renders.
