Massa crashes after being hit by heave spring
mpbx3003
mpbx3003
Re: Massa crashes after being hit by heave spring
I'm really starting to think there was a failure of some sort with the HANS device. How many big straight-on crashes have there been in the past few years? Ralf at Indy, Kubica at Canada, just to name two. This is the only one I've seen where the drivers head goes forward violently. It might be that the initial spring hit jerked the yoke loose, but maybe Felipe had loose belts or some other improper use. I just hope this isn't the end of his career, though he'll probably be done for the season.
Ray
mpbx3003 wrote:I'm really starting to think there was a failure of some sort with the HANS device. How many big straight-on crashes have there been in the past few years? Ralf at Indy, Kubica at Canada, just to name two. This is the only one I've seen where the drivers head goes forward violently. It might be that the initial spring hit jerked the yoke loose, but maybe Felipe had loose belts or some other improper use. I just hope this isn't the end of his career, though he'll probably be done for the season.
Kimi in Monza 2007 went really far forward as well.
http://www.clipser.com/watch_video/40357
zx9rc1
zx9rc1
zx9rc1 wrote:
mpbx3003 wrote:
ESPImperium wrote:Im just glad that his HANS device did its job and stopped his head from slamming into the steering wheel and causing more damage to his head.
Did it? It looks like he slammed his head on the steering wheel to me. The skull base fracture suggests that he did.
I think he hit the steering wheel too but like in Mikas crash it happened very quickly
From what I can see because it happens so quickly, he hits the tyre barrier, the steering wheel turns hard right and he hits the left corner of it with the left side of his helmet
joseff
I don't think the spring completely knocked him out. A full application of F1 brakes isn't exactly the sort of thing an unconscious man could do. Punch drunk enough to keep the throttle wide open, but semiconscious enough to reflexively stand on the brakes.
Ray
I watched one video and you could see right at the time of impact the G meter on the right increased by .2! That's amazing. But I think the telemetry may be wrong on the brakes being applied, but how else can you explain the wheels being locked up from the grass to the tires? He had to be somewhat awake.
mpbx3003
mpbx3003
Ray wrote:Kimi in Monza 2007 went really far forward as well.
I don't think you can really compare those two crashes, Massa's head doesn't look restrained at all. You can see the bottom edge on the back of Massa's helmet, but Kimi's head only goes far enough to see halfway down the back. That said, Kimi's head does go further than usual. Maybe Ferrari have some problem with the device.
zx9rc1
zx9rc1
Ray wrote:I watched one video and you could see right at the time of impact the G meter on the right increased by .2! That's amazing. But I think the telemetry may be wrong on the brakes being applied, but how else can you explain the wheels being locked up from the grass to the tires? He had to be somewhat awake.
The car has gone across the grass some distance, so the tyres have picked up loads of debris so are only working at probably 30% of normal grip, the car would be light coming down off the kerb after the grass and also the run off area would compound the issue by being dirty, add in the fact the fronts were probably locked but the rears may have still had enough drive on full throttle to just plough the car straight on and overcome the brake force to some extent. Which is maybe why they were locked up all that distance. Hard on the brakes but no effective retardation as you would normally get
Which other motor sport do they strap the helmet to the car again?
Nascar or NHRA?
Ray
Good point
Ray
n smikle wrote:Which other motor sport do they strap the helmet to the car again?
Nascar or NHRA?
I think the NHRA do. But their version of the HANS device goes to the small of the back and is clipped in around the midsection as well. I know WoO strap the arms to the center buckle to keep drivers arms from flailing around as well.
zx9rc1
zx9rc1
Good point
Looking at the video again at about 8 secs, I dont event think the car is touching the ground after it comes off the kerb until at least 70% across the track
Giblet
Giblet
Coulthard was saying based on the fact that there are only two skid marks visible, not 4, suggests that Filipe's foot was on the brake pedal already.
Based on that, I figure that many people tense up when hit in the head, and stomped both pedals.
zx9rc1
zx9rc1
I agree with this, even before he hits the barrier his head is bobbing about all over the show, When you have Hans on its not that loose from when I have worn it, only in impact do the belts and straps stretch, they do loosen off but usually in qualifying you arent out long enough to need to readjust them. Your belts should be done up so tight it hurts to some extent and its difficult to breathe to start with. You can move your head side to side but not backwards and fowards that easily.
Callum
Im always for looking at the bright side of things..
if the spring had hit maybe two inches lower i think the weaker visor would have taken the full blow.
could have been worse.
i hope he makes a full and speedy recovery.
mpbx3003
mpbx3003
I've never worn HANS myself, so can you answer a question? How easily can you remove the tethers? I was thinking that maybe the spring, when it bounced around after hitting him, might have knocked one of them loose.
