McLaren MCL36
siskue2005
70
Re: McLaren MCL36
DragonSGC wrote:
07 May 2022, 16:30
Perhaps running the stay this weekend is gathering data for the Spain upgrade package, we have never needed it in the past so perhaps the spain upgrade either means a lighter (and hence more flexing) floor or perhaps less of the floor will be supported like it is currently on the car.
Stay is good for saving weight, as they dont need to run a heavy floor to prevent it flexing down and causing porpoising.
Mansell89
Mansell89
Re: McLaren MCL36
Anything specific in the way of upgrades and things the team are working on guys?
Quite excited to see what the grid bring to Barcelona- first proper upgrade of the new era.
_cerber1
262
Re: McLaren MCL36
A clear hint at updates, the only question is what it will be and how much it will bring us in the end.
Lucky
Lucky
157
Re: McLaren MCL36
Re: McLaren MCL36
Close-up of the stay...
_cerber1
262
Re: McLaren MCL36
In the race, this spacer was not.
MrGapes
Re: McLaren MCL36
From what we’ve heard from PhillipM and other media sources… Front brake ducts, rear brake ducts, rear brake winglets, front strake section….
This is just from what we have heard, maybe not all of this… but it has been a while so obviously they’ve put considerate energy into the production of this package
_cerber1
262
Re: McLaren MCL36
There are rumors that the second MB motor that will be introduced in Spain will be more efficient, which should help us.
Re: McLaren MCL36
_cerber1 wrote:
11 May 2022, 14:30
Since they can't change any parts, Ican't see how that's true.
Re: McLaren MCL36
diffuser wrote:
11 May 2022, 14:56
_cerber1 wrote:
11 May 2022, 14:30
"Reliability" changes still allowed ??
Re: McLaren MCL36
mclaren111 wrote:
11 May 2022, 16:35
diffuser wrote:
11 May 2022, 14:56
_cerber1 wrote:
11 May 2022, 14:30
Yep but he said more efficient. It used to be that these changes would get looked at by the PU Manufactures for aproval AFTER the FIA approved them. Not sure if it still happens that way.
Alpine got approval for thier Revised water pump but that's kind of a no brainer when it comes to a "reliability" fix. No way a water pump can give you more power.
georgekyr
georgekyr
Re: McLaren MCL36
It might just be new maps to extract more performance from the E10 fuel at different engine loads and rpms now that they also have at least some component wear data. This is still allowed. The rocket engine was based on this principle last year.
Re: McLaren MCL36
diffuser wrote:
11 May 2022, 16:48
mclaren111 wrote:
11 May 2022, 16:35
diffuser wrote:
11 May 2022, 14:56
A lighter, more efficient impeller for the water pump impeller gives less drag on the engine which translates to more power at the wheels. I'm not talking big difference but could they find 0-1hp between a heavy, inefficient impeller, and a light weight, efficient flow design? Sure.
Virtually every reliability tweak has performance consequences. What I think is each manufacturer is scratching the other's back in order to receive favors when it's their turn to ask for something.
A lion must kill its prey.
LM10
LM10
121
Re: McLaren MCL36
12 May 2022, 03:17
diffuser wrote:
11 May 2022, 16:48
mclaren111 wrote:
11 May 2022, 16:35
And how are you going to pass a lighter water pump off as a reliability upgrade?
djos
113
Re: McLaren MCL36
A majority of the other teams have to agree to allow the reliability update tho, so it wouldn’t be easy to get performance improvements past them.
"In downforce we trust"
