Can't be any worse than 2018.
Juzh
161
godlameroso wrote:
05 Feb 2019, 14:09
This would be a failure in itself. A massive one at that.
Craigy
84
godlameroso wrote:
05 Feb 2019, 14:09
Speculation.
Introduction-level new concepts can perform worse than evolved versions of old concepts.
Lets see how testing goes.
That may be an issue, however I don't see iterative changes as bringing big problems. Not on year 3 of the current spec at least. Frankly I'm more concerned about Renault's reliability than I am Honda's.
Snorked
Snorked
68
Interview with Asaki and Yamamoto about 2018 and what's coming next
etusch
131
Honda wants "no grey areas" in F1 engine regulations
We were the ones who came in the later time, so we were behind from the point of view of knowledge and understanding," he said.
"So, what Honda thinks is we want to burn all of those grey areas. We want them to stop - no grey areas is our hope.
"We did so much trial and error and we studied a lot from that. From that we can have some steps forward, and that can be connected to next year."
https://www.motorsport.com/f1/news/hond ... s/4331445/
A lot of the most significant discoveries tend to be found as side effects of a trial and error approach.
There are always more wrong answers than right ones, so whittling away the wrong ones give the right ones the chance to reveal themselves.
Machine learning is dependent on good input, and there will always be a trial and error phase before the input can be good enough for machine learning to take over.
Machine learning won't help much.. yet.. it is not mature enough.
Check out robo-race. A human will still beat them around a simple course, much less failure analysis.
Deep learning is sorta different, but mostly statistics if I understand it.. not much related to designing engines? I don't know..
Hkbruin2
Hkbruin2
https://youtu.be/zfkDH4amASQ
STR14 RA619H fire up!
ispano6
157
The best sounding Honda ICE yet.
Bence
Bence
OMG, what a silky engine texture when all cylinders are firing!!!
The sound is fascinatingly similar to the bark of the RA16X-series...
Maritimer
Maritimer
19
Always liked the Hondas sound
GhostF1
GhostF1
110
godlameroso wrote:
09 Feb 2019, 03:33
Agreed. And also, correct me if I'm wrong, but it's also the first time we've heard a Honda PU running on all 6 cylinders while stationary. Usually it remains in the cut cylinder mode until moving.
Great sounds coming from the engine. So keen for testing to start!!!
restless
restless
I think on low rpm it still sounds like cylinder deactivation is working?!
