Because their ultra-high chassis can manage a wonderful amount of air which is hampered by their 135mm height nosebeelsebob wrote: Why do you believe that a penis nose would do that?
Seeing their S2 times, Ferrari lacks also a bit of rear downforce!Ferrari keep saying that they are very fast in the high speed corners, which would suggest, that they are doing well downforce wise. After the race Alonso said that they were lacking in traction and top speed.
It's not simple. We are below the speed of sound, so the air can travel around obstacles without loosing that much energy in certain cases. Look, for example, at RB's monkey seat located below exhaust, completely shadowed from the free stream.Javert wrote:Well that's a simple m^3 volume computation!
http://www.autoweek.com/galleryimage/CW ... -VJM07.jpg
http://richlandf1.com/wp-content/upload ... t-nose.png
I'm not speaking about the chassis quality, I'm speaking about the air volume
How can you tell from a singular sector time it is not a front downforce? Or that is a downforce issue at all? It's not like S2 is all corners. It has quite a bit of acceleration zones too. The results in S1 and S3 is probably inflated for everyone except Hamilton/Vettel and Rosberg as others used DRS at some points. So the picture is skewed, it's not easy to get fair picture from it.Seeing their S2 times, Ferrari lacks also a bit of rear downforce!
Last year it would clearly mean suspension/aero problem, this year it can be engine/ERS performance too. Merc is overall best engine is all three aspects: power, consumption, driveability.atlantis wrote:Ferrari drivers have to do a lot of corrections with the steering wheels, which are moving and vibrating a lot. Mercedes looks very stable and drivers do almost no corrections: why do you think it happens? Too much oversteering?
While it is indeed true, it seems that Merc has easier time putting the power down this year in general.Jersey Tom wrote:Mercedes driving away from the field in 1st and 2nd pretty comfortably... you don't need to push the car very hard. Cruise control mode, managing tires and engine, driving under the absolute limit of the car.atlantis wrote:Ferrari drivers have to do a lot of corrections with the steering wheels, which are moving and vibrating a lot. Mercedes looks very stable and drivers do almost no corrections: why do you think it happens? Too much oversteering?
Much different when you're really pushing and trying to battle for positions.
If you think it's a simple m^3 volume computation, what on earth makes you think the Ferrari engineers haven't done it? Had you not considered that they might have done that computation, and done some other computations and simulation, and settled on a different nose design from the "obvious" one an armchair aerodynamicist would have come up with?Javert wrote:Well that's a simple m^3 volume computation!beelsebob wrote:What makes you believe that you can tell with the naked eye, how much air gets under the nose of the Ferrari compared to any other design of nose? Not only that, but figure that out better than a bunch of trained aerodynamicists at Ferrari can with actual real tools and modelling?
B,bhall wrote: .....
These designs have the potential for less drag than other dick-nose designs. Not only does the phallus have a tendency to disturb air flow, simply allowing a loooooooong boundary layer to form under the chassis carries the risk of increased drag due to the tendency of boundary layer flow to thicken downstream, which effectively increases the size of the chassis.
.....All of this is to say, there are no black-and-white, good-or-bad solutions this year. At least not yet. I think the designs are simply too immature to judge at this point.
Honestly, I thought it was a given at this point that cars endowed with dude-pistons are indeed an attempt to maintain previous years' high-nose conventions. After all, the sole reason for the new carbon fiber spawnhammers is to leave the low-nose mandate breathless, quivering, and unwilling to object. Otherwise the design appears to lack a genuine desire to go down on the spirit of the rule.flyboy2160 wrote:B,
I'll buy your last paragraph, but not the part about the phallus noses increasing drag compared to a non-phallus low nose like Ferrari's. I could argue the other side that, in the absence of separation, (subsonically) wetted area drives drag. The low noses have both more wetted area and, by the looks of it, probably more separation on the back/lower faces. I could also argue that the phallus noses appear to be trying to maintain the Postlewaite high nose flow philosophy to whatever extent they can, while Ferrari looks like it has abandoned it and gone on to try something different.
Once you've lost the energy from the air, trying to reenergize it will always cost you something. So I'm not buying the argument that Ferrari can reenergize the air behind the low nose to make it as if it was a high nose.
It is fascinating to me to see how this will all shake out.
Flyboy Steve
F14T traction problems are engine related.heidenreich27 wrote:I was just asking, because suspension changes could improve traction.
