Mclaren MP4-30 Honda
aleks_ader
90
Re: Mclaren MP4-30 Honda
stevesingo wrote:Comparisons for sector times on L24 against the midfield cars. (H6) denotes tyre fitted and laps done on that tyre. (S+-10) denotes the speed difference at the sector line.
S1
JB(M2) S269 26.801
RG(M8) S+19 26.202 -1.06%
FM(M19) S+15 26.971 +0.63%
MV(H3) S+7 26.781 +0.03%
DR(H5) S+15 26.390 -1.53%
SP(H6) S+23 26.475 -1.22%
S2
JB(M2) S127 36.814
RG(M8) S-2 37.146 +0.90%
FM(M19) S-4 37.810 +2.70%
MV(H3) S-4 36.724 -0.24%
DR(H5) S-1 37.315 +1.36%
SP(H6) S-1 37.085 +0.73%
S3
JB(M2) S261 43.353
RG(M8) S+6 43.379 +0.06%
FM(M19) S+8 43.937 +1.34%
MV(H3) S+8 43.338 -0.03%
DR(H5) S+12 43.343 -0.02%
SP(H6) S+9 43.654 +0.07%
Unfortunately, McLaren were on a different strategy to all except Lotus. Surprising to see that the Lotus is not much faster in S1 where we have 2/3 of the pit straight. This could be because they were not running a lot of down force which would pay dividends on the straight (they were 10kph faster in qualifying) and 19kph faster on the straight after turn 3 so presumably losing out in the long turn 3. This may imply that the MP4-30 is a little better in the corners when we consider the MP4-30 is faster than the Lotus in S2 and by the speed trap speeds may have better traction as the MP4-30 is 2kph up on the Lotus at the sector end speed trap. The MP4-30 is also surprisingly quicker in S3 with the full length back straight. Despite a 10kph speed advantage on the back straight in qualifying, the MP4-30 must be overcoming that speed deficit in turns 11-14. This again points to better cornering ability.
IMO, with more power the MP4-30 should be able to overcome the Lotus.
Okay: let clear this up: JB=Jenson BUtton, FM= Fernando? Why not FA, RG=romain G, MV=Maldo?, DR=Daniel R?, SP=? Counfusing and i hate guessing.
Why not use simmpler innicials according key: "1stname"+2nd "name" for exapmle Romain Grojean is "RG" or use even more standard "FOM " 3 charachers abbvrevations, i mean those wich we see during TV stream like ALO, GRO, BUT etc.
My thoughts: FM=Felipe Massa, MV = Max Verstappen, SP = Sergio Perez, DR = Daniel Ricciardo
If you know all the Drivers Names it helps a ton. :lol:
btw: I have a feeling that whole discussion will be deleted sooner rather than later. :D
aleks_ader
90
Thunders wrote:My thoughts: FM=Felipe Massa, MV = Max Verstappen, SP = Sergio Perez, DR = Daniel Ricciardo
Massa miedfield car? I dint think on that #-o Ha ha
Bv. mods move those post into Team thread THX
So, to get back on Topic:
The McLaren Updates in Malaysia by AMuS.
GoranF1
GoranF1
155
Fantastic @Thunders! =D>
Looks like they made those s-Šaht tubes a bit in a hurry... :D ...american duct tape it is!
GoranF1
GoranF1
155
aleks_ader wrote:Deleted WiFi problems
its not WIFI.....forum has been double.triple posting for days now....you just have to be patient and wait for 2 minutes when you press submit....
Tim.Wright
330
Looks like some flexural loading of the rigid body rules going on there...
miguelalvesreis
miguelalvesreis
Or just wait some seconds and hit F5 and you'll see below on the topic review that your post is already there
stefanf1
stefanf1
Vortex Generators push the front wheel wake over the rear wing, as a ambulant air flow creates less down force at the rear.
stefanf1
stefanf1
Vortex Generators push the front wheel wake over the rear wing, as a ambulant air flow creates less down force at the rear. good idea to have 3. :)
Amus:
They also tested with smaller number of gills =D>
McMrocks
McMrocks
32
stefanf1 wrote:Vortex Generators push the front wheel wake over the rear wing, as a ambulant air flow creates less down force at the rear. good idea to have 3. :)
...and i always thought the vg's on top of the sidepod help keeping the airflow attached to the bodywork.
Of course you want the tyre wake to be far away from RW and diffuser but i don't think that the vgs deflect the front wheel wake
Thefuelman
Thefuelman
ajnšpric_pumpa wrote:Fantastic @Thunders! =D>
Looks like they made those s-duct tubes a bit in a hurry... :D ...american duct tape it is!
It gets even worse, It looks like the connections from the front wing pylon supports to the front wing got the same treatment. :o Duct tape it is. Reminds me of the early Mercedes cars circa 2010 to 2012.......
trinidefender
trinidefender
317
You want the front wheel wake as far away from everything as possible. In fact you want to reduce the front wheel wake as much as possible. That is where the idea for having so much out wash on the front wings came from. The blown wheel nuts. And generating a vortex around the front wheel though the use of the out was front wing and the turning vanes under the nose push air into the low pressure, twisting mass of air. By reducing this twisting and tumbling of air you reduce the negative effect it has on aerodynamic parts further down the car. By reducing the size of the low pressure region and reducing the low pressure gradient behind the tyre you are reducing the drag created by that wheel. Therefore controlling flow around the front wheels is critical to both reducing drag and creating downforce at the back of the car.
dren
226
double....delete please
Honda!
