Ferrari F2012
Giblet
Giblet
Re: Ferrari F2012
dren wrote:
Raptor22 wrote:The pull Rods work I guess because the suspension does'nt travel very far. With a stiff front end and and soft rear thats been the rage I guess they feel they don't have to worry too much about perfect suspension geometry.
Its a mistake I fear. Good suspension is good suspension and you can;t overcome a poor one with good aerodynamics
Just my opinion
I don't see the aero benefit from a pullrod front though.
I think he is just saying the car needs good aero and good suspension geonetry, not that the pull rods in the front provide that aero.
timbo
timbo
113
Re: Ferrari F2012
munudeges wrote:I must confess I don't see the reason for the front pull-rod suspension.
Imo to place the weight lower.
Lorenzo_Bandini
Lorenzo_Bandini
Re: Ferrari F2012
Jamesallenonf1 James Allen
#f1 There are so many legality question marks around 2012 F1 cars apparently, that FIA's Charlie Whiting is going to attend Jerez test...
ledzep4pm
Re: Ferrari F2012
Just my opinion
I'm also struggling to see an advantage. But I have had a couple of thoughts:
Possibly a lower C of G for the suspension components as they will have to be mounted differently. Also this might have made it easier for them to work in the crocodile nose.
This is just speculation, I can't see how having the higher pull rod would give a measurable advantage over the diagonal/lower push rod in terms of mass flow rate to the rear of the car or of the air quality (i.e less turbulent)
Twitter @ledzep4pm
neilbah
neilbah
Re: Ferrari F2012
There seems to be a rectangular duct in the front of the beam wing, the rear brake fins/ducts seem to be massively ramped diffusers from the rear
sknguy
sknguy
Re: Ferrari F2012
It'll be interesting to see how the Pirellis perform with an entirely pullrod suspension, if there's any difference in attitude control at all, however subtle it might be. Would they not have an effect on something like roll center?
amouzouris
105
Re: Ferrari F2012
i have edited a two photos...
http://imageshack.us/f/341/ferrarif201220122150.jpg/
in this one its the f2012 side by side with the 150 italia....
http://imageshack.us/f/401/ferrarif20122thin.jpg/
and in this one i have edites out the bulges in the sidepods as someone had requested...
RacingManiac
RacingManiac
Re: Ferrari F2012
sknguy wrote:It'll be interesting to see how the Pirellis perform with an entirely pullrod suspension, if there's any difference in attitude control at all, however subtle it might be. Would they not have an effect on something like roll center?
Your roll center is govern primarily by your control arm...
Pull or pushrod can do the same thing given the same task mechanically speaking, however so much of F1 is driven by other concern that there may well be some differences in the end.
i70q7m7ghw
i70q7m7ghw
49
Re: Ferrari F2012
I'm thinking the same to be honest... I just don't see the benefits. Very much doubt any other cars will have front pull-rod, pretty sure Red Bull won't be running it either.
shelly
shelly
136
Re: Ferrari F2012
All the changes Ferrari has made sem to be propelled by a big change in structure analysis and project. Does anybody know if, and how much, people have changed in the structures department?
twitter: @armchair_aero
Giando
93
Re: Ferrari F2012
From my brilliant friend and compatriot Michele Dragoni, boat designer and motorsport lover...
Who's talking about british-humour now? :lol:
Ferraripilot
21
Re: Ferrari F2012
With less suspension movement at the front end would this tear up and/or heat the front tires further? It sounds like this suspension could allow Ferrari to establish a lower static ride height but would it be at the expense of degradation I wonder
Redragon
19
Re: Ferrari F2012
http://jorgelizalde.co.uk/ferrrari/Untitled-1.jpg
Mclaren and Ferrari front view side by side.
I tried to match them but the picture of ferrari is taken from lower point of view.
But you can see the different. If mechanically Push rod and Pull rod suspension do the same.
I understand why Ferrari is using Pullrod look how clean it looks like underneath.
KevinR34
KevinR34
Re: Ferrari F2012
This looks much better with McLaren nose + rims :D Mcrrari MP4-F2012. My photoshopskills are not so high level but im happy with the result :P
Caterhamrules
Caterhamrules
Re: Ferrari F2012
