RZS10
359
Or it came from some part that lies between the intercooler and the cylinder ...
Zynerji
111
RZS10 wrote:
18 Apr 2023, 17:29
Like a sensor.
chrisc90
Probably dropped a valve, most likely scenario really.
Would turbine fragments, if the cold side of turbo blew, make it through a intercooler?
Edax
Edax
47
RZS10 wrote:
18 Apr 2023, 17:29
Sounds like the type of language a marketing department would use to avoid having to say that an unfortunate engineer dropped a washer in a place it didn’t belong.
Embarrassing but nothing beyond that.
Big Tea
99
chrisc90 wrote:
18 Apr 2023, 18:42
My first thoughts were valve (or part of) or plug electrode
No one should expect Mercedes to admit to anything interesting....no PU manufacturer ever does.
A lion must kill its prey.
saviour stivala
saviour stivala
"Ingested":- To me it means something that gets into a cylinder from outside of it, and as an air filter on the engine intake is used, whatever found it's way into a cylinder is not from the outside of the engine, but from the engine itself. This is unlike the other Mercedes engine that ''swallowed'' or dropped a valve inside the cylinder, which it itself is partly already inside a cylinder.
Vaexa
Vaexa
I just find the idea of foreign debris making its way past the air filters, compressor and intercooler without exploding the compressor into a million pieces a little difficult to believe, personally.
The fact that it's being called "debris" cracks me up.
chrisc90
Vaexa wrote:
18 Apr 2023, 22:47
Next to impossible without complete carnage.
Possibilities are.... valve dropped, spark plug failed dropping ceramic down, no spark causing det/supersonic knock? (might be a little extreme for fully blown failure but could melt a piston), injector failure.
Rodak
Rodak
37
I'd include valve seat in that list. A nice regulation for technical fans would be to require an engine manufacturer to actually explain what happened.......
Rodak wrote:
19 Apr 2023, 03:06
Why? The information is proprietary. These are trade secrets.
Anything that is weak or can be loosened in the intake system I guess. The good news is, that it is unlikely to happen again.
Rodak
Rodak
37
19 Apr 2023, 03:15
Rodak wrote:
19 Apr 2023, 03:06
The design and technology is certainly proprietary, but the reason(s) for the failures probably aren't as evidenced by the previous list; the proprietary information is the solution to the problem. My point is that it would be interesting for technical fans if the teams had to describe the failure. The FIA allows modifications to power train components to fix reliability issues, so why shouldn't the teams be required to explain what these issues are to all of us? For an engine manufacturer to get approval to modify an engine for reliability they have to submit their proposed 'fix' to all other engine manufacturers for comment and approval so 'proprietary' is weak sauce.
saviour stivala
saviour stivala
chrisc90 wrote:
18 Apr 2023, 23:09
Vaexa wrote:
18 Apr 2023, 22:47
At least to me it seems close to what happened to FERRARI last year, meaning, and this was never official from FERRARI, which was said to be ''A spark-plug melt down". A spark-plugs nowadays includes the passive pre-chamber build into it.
