How come this gill is allowed? It is not connected to the exhaust opening with a slit as far as I can see. Can anyone explain?siskue2005 wrote:
Code: Select all
3.8.5 Once the relevant bodywork surfaces are defined in accordance with Article 3.8.4, apertures, any of
which may adjoin or overlap each other, may be added for the following purposes only :
- single apertures either side of the car centre line for the purpose of exhaust exits. These apertures
may have a combined area of no more than 50,000mm 2 when projected onto the surface itself. No
point on an aperture may be more than 350mm from any other point on the aperture.
- apertures either side of the car centre line for the purpose of allowing suspension members and
driveshafts to protrude through the bodywork. No such aperture may have an area greater than
12,000 mm 2 when projected onto the surface itself. No point on an aperture may be more than
200mm from any other point on the aperture.
