It up there wit calling it a 'RUD' incident (rapid unscheduled disassembly) .
Why?
That’s a lot of hoops it has to go through before it reaches the engine. It has to pass a turbo impeller at 200k+ rpm to start with. Then pass through the intercooler, I’ve no idea how big the air tubes are on a F1 intercooler but they are narrow enough on a road car.basti313 wrote: ↑19 Apr 2023, 11:10Why?
The report is debris...a sharp piece of CF can easily cut through the air filter and pass intercooler and turbo without issue. The issue is then the valve.
keyword is MAY... its all speculation unless its from an internal leak from a senior staff at brackley...pursue_one's wrote: ↑19 Apr 2023, 13:10- Merc’s side pods may not change as much as you think
- the cockpit position may stay the same in W15
https://open.spotify.com/episode/7EvEB3 ... sebOg&nd=1
So Elliott is moved to a more hands-off role. Not surprising.pursue_one's wrote: ↑21 Apr 2023, 12:42James Allison is back!
https://www.motorsport.com/f1/news/merc ... /10458942/
Perfect timing for Leclerc to joinorganic wrote: ↑21 Apr 2023, 12:49So Elliott is moved to a more hands-off role. Not surprising.pursue_one's wrote: ↑21 Apr 2023, 12:42James Allison is back!
I wonder how long it will take Allison to right the ship. Shouldn't be more than 2 seasons
Who knows, 2023 seems ambitious that's for sure. But similar to how people always exaggerate how important Newey is relative to the rest of the RB technical department, people might exaggerate the effect Allison will have.organic wrote: ↑21 Apr 2023, 12:49So Elliott is moved to a more hands-off role. Not surprising.pursue_one's wrote: ↑21 Apr 2023, 12:42James Allison is back!
he was doing debriefs last year in singapour, doesn't mean much but he was involved in W13
Obviously Italian media so they're much more reliable when it comes to Ferrari, but previously the info of the tolerances/Allison's inclusion had been lower quality sources iirc.parts used in the wind tunnel (to scale) were inaccurate and produced outside the permitted tolerances. These problems have not only affected the development of the W14 but also in terms of correlation. This also led to the dismissal of some people who followed the production.
