Mercedes-AMG F1 W10 EQ Power+
zibby43
zibby43
Re: Mercedes-AMG F1 W10 EQ Power+
OO7
OO7
171
A few more updates spotted:
1) The old version (yellow) was squared off, while the new section (red) is a diagonal piece.
2) The old version (yellow) had a sharp straight cut edge, while the new vane blends diagonally into the main bargeboard section.
3) The old version (yellow) has a tall diagonal section roughly the same height as the short square (sideways rectangle) section above that it connects to, while the new version (red), has a shorter, lower diagonal section and taller square upper section.
1) The old version (yellow) has two vanes, the first being completely vertical and the second being shorter than the first and with an angled top. The new version (red), has a first vane which cants/curves outwards slightly, the second vane is taller than the older version and cants outwards giving the element a 3D like twist.
2) The old version (yellow) is a shorter, single continuous element, whereas the new version (red) is taller and features a partial split, almost dividing the section into 2 elements.
3) The old version (yellow) features a short outer edge, while the new version (red) has a taller outer edge.
The rear vane behind the front three has also been re-profiled.
zibby43
zibby43
According to Motorsport.com, there are some additional changes to the front wing:
"This [new front wing] features a shorter overall chord length, shortening the top two elements to bring the trailing edge further forward along the endplate."
Here's a pretty good angle on the inside portion of the end plate:
Via Giorgio Piola
Pyrone89
Can we call this a B-spec officially, seeing how many changes at once are made?
Pyrone89 wrote:
25 Jul 2019, 22:55
I wouldn't say so. Changes here and there but nothing major making it a new car. It's a Spain size package.
Pyrone89
MtthsMlw wrote:
25 Jul 2019, 23:01
Pyrone89 wrote:
25 Jul 2019, 22:55
:wtf:
Literally every piece of bodywork has 1 or more (large) visible changes, a new monocoque and new cooling
Pyrone89 wrote:
25 Jul 2019, 23:08
MtthsMlw wrote:
25 Jul 2019, 23:01
Pyrone89 wrote:
25 Jul 2019, 22:55
:wtf:
For me these are all normal developments not changing the concept or philosophy of the car. If these updates were brought to the car one step at a time and not all at once I don't think you would call this a B-spec compared to what it was in Spain for example.
OO7
OO7
171
Pyrone89 wrote:
25 Jul 2019, 23:08
MtthsMlw wrote:
25 Jul 2019, 23:01
Pyrone89 wrote:
25 Jul 2019, 22:55
:wtf:
There's no new monocoque as far as we know.
mkay
mkay
16
Pyrone89 wrote:
25 Jul 2019, 23:08
MtthsMlw wrote:
25 Jul 2019, 23:01
Pyrone89 wrote:
25 Jul 2019, 22:55
:wtf:
The rumours of new lightweight chassis have been quashed by Mercedes.
Pyrone89
mkay wrote:
25 Jul 2019, 23:27
Pyrone89 wrote:
25 Jul 2019, 23:08
MtthsMlw wrote:
25 Jul 2019, 23:01
:wtf:
Can you provide a source, only heard a poster mention it
OO7
OO7
171
zibby43 wrote:
25 Jul 2019, 22:39
https://cdn-4.motorsport.com/images/mgl ... wing-1.jpg
Via Giorgio Piola
Comparing the long chord older front wing, with the new short chord version:
Maritimer
Maritimer
19
Did the front wing always have the proud center section?
zibby43
zibby43
Blaze1 wrote:
26 Jul 2019, 00:47
zibby43 wrote:
25 Jul 2019, 22:39
Via Giorgio Piola
https://cdn-3.motorsport.com/images/mgl ... wing-1.jpg
Perfect comparison shot mate. Thanks!
OO7
OO7
171
You're welcome. :)
