I would want to know what things they can’t monitor. The modes may be many and complex but most of the the things they monitor are not. If they can’t monitor the elements of the mode they’ll be fooled whether there are many or just one.
You think Merc will only sign if they get the guarantee by the FIA to win the next 5 years? But maybe this is it...as many of us think the Merc engine will be even better than the others with modes banned because of its superior overall performance, lifetime and efficiency.WaikeCU wrote: ↑13 Aug 2020, 23:16I hope this doesn't lead to Mercedes just pulling the plug of their F1 program. We already are in times of crisis globally, but also economically. Don't think FIA could just force a manufacturer to sign the Concorde Agreement and because they refuse to sign, they face consequences by pulling performance off their cars and getting calls against them.
Merc leaving could mean that we potentially only have 1 former champion on the grid for next season. Mercedes were rumoured leaving F1 in the near future, but this could just put things into a high gear.
Yes, because as we have seen before drivers can and will screw it up from time to time, and will get overtaken because of it.
butESPImperium wrote: ↑13 Aug 2020, 23:41This is bloody sense. Let the driver drive, let's get rid of the 9 to 11 rotaries on a steering wheel and the 40+ buttons and switches on some steering wheels. Ive always said this is a breach of Parc Ferme rules, a change in specification.
Why 5? If it's a breach of the rules, why have any? Why have an arbitrary number thought up by you?Id like to see rotaries limited to 5 and buttons and switches with the McLaren PCU-8D on it facing the driver and just a two clutch paddles and two gear change paddles on the rear.Teams can come up with their own designs.
Because you have to ration their use. So a faster driver behind can harry the leading car into using it's small ration of high engine modes in order to keep ahead. Then, when it exhausts its ration, the car behind turns the engine up and might actually be able to pass.
The more you reduce things to random chance, the less you reward skill. And why are we excluding all the people who bring their skills to the table, in favour of the drivers?
Add to that, drivers to run at the shot of a gun fire and grab their seats and then race off. No assistants to put the seat belt, because, driver has to drive the car unaided.Just_a_fan wrote: ↑13 Aug 2020, 23:56butESPImperium wrote: ↑13 Aug 2020, 23:41This is bloody sense. Let the driver drive, let's get rid of the 9 to 11 rotaries on a steering wheel and the 40+ buttons and switches on some steering wheels. Ive always said this is a breach of Parc Ferme rules, a change in specification.Why 5? If it's a breach of the rules, why have any? Why have an arbitrary number thought up by you?Id like to see rotaries limited to 5 and buttons and switches with the McLaren PCU-8D on it facing the driver and just a two clutch paddles and two gear change paddles on the rear.Teams can come up with their own designs.
Why stop at 5? Let's just go back to simple engines fitted with carbs, and a manual gearbox with an H-pattern manual shifter in the cockpit. No buttons at all. Absolutely no way the driver can be aided then, eh?
A couple things, for purposes of clarification.
What are qualifying modes?
Qualifying modes make available extra engine revs and the ability to run without harvesting power and diverting it to the battery, thereby allowing maximum deployment of energy recovered via the two energy recovery systems. These modes also typically run more aggressive ignition timing and fuel mixture.
By contrast, a standard race mode will allow adequate harvesting to keep the battery supplied with energy that can be deployed through the lap – without draining the battery and thereby compromising the following lap. It will also typically run lower maximum revs than the qualifying mode and a setting of ignition timing that keeps the valves and piston crowns at a safer temperature.
Typically there are several – up to nine – modes in between the two extremes. This is all about trading off performance with engine life, reliability and fuel consumption.
So what’s the proposed change?
Previously the qualifying and overtake modes would have a time limit per event imposed upon them by the engine manufacturer, so as to keep the power unit within its usage limit. A letter sent to the teams at Barcelona suggests that the subsequent Technical Directive will require the power unit to be run in the same single mode during qualifying and race. This has yet to be confirmed by the Technical Directive itself.
Why is this rule being implemented now - and what impact will it have?
To assist policing. The FIA has to police a number of power unit parameters through very detailed data analysis, and it is felt that this directive will help them achieve that – and have more confidence of power unit legality as a result. Of course, a consequence of the move would be to clip the wings of the power unit which shows the biggest power boost between normal and qualifying modes. At this point that's believed to be Mercedes, with Ferrari showing the least difference between the two modes. Renault and Honda are quite similar in between those two extremes.
The move would save expensive development programmes for Honda, Renault and Ferrari at a time when the FIA is very actively trying to close down cost drivers. As a downside, it would reduce the differences in power at any given moment between two dicing cars. Often the passing we see in hybrid F1 era comes from one driver forcing another to use up his energy store defensively, then having none left as the attacking driver deploys.
I think this is only strategy if you look at it in a very theoretical and dreaming way. I do not see this in the races. Hunting a car into depleting engine modes is simply not possible with current tires. In the end only the tire defines who overtakes and who does not and if you hunt a car so close to deplete its engine modes, then you finish 10 sec behind because your tires will fail...Wynters wrote: ↑14 Aug 2020, 01:03Because you have to ration their use. So a faster driver behind can harry the leading car into using it's small ration of high engine modes in order to keep ahead. Then, when it exhausts its ration, the car behind turns the engine up and might actually be able to pass.
It's no different to fuel use. Or tyre use.
It's strategy.
Really? is this from FIA? or Liberty? so they are acknowledging only Honda, Renault and Ferrari are not using this mode? and it is going to effect only Merc, not anyone else. So that is their aim..etusch wrote: ↑14 Aug 2020, 08:30sory if it is already sharedWhat are qualifying modes?
https://www.formula1.com/en/latest/arti ... UFncL.html
