Ferrari F14T
Re: Ferrari F14T
DETAILED ANALYSIS BLOWN WHEELNUT FERRARI F14T
http://translate.google.com/translate?s ... -f14t35%2F
Re: Ferrari F14T
Spain 2014 - Thursday (08.05.2014)
miguelalvesreis
miguelalvesreis
Re: Ferrari F14T
stefan_ wrote:Spain 2014 - Thursday (08.05.2014)
http://img3.auto-motor-und-sport.de/Fer ... 777183.jpg
Megaphone exhaust?
George-Jung
George-Jung
Re: Ferrari F14T
If you compare this picture:
with this picture (I know it is a Marussia):
http://i.imgur.com/ht57eec.jpg
Than it looks like Ferrari have managed to 'clean' it up impressively.. les wires etc..
nhojekim
nhojekim
Re: Ferrari F14T
Is it just me, or the exhaust just became bigger?
painkiller
painkiller
Re: Ferrari F14T
Yes i think so.
George-Jung
George-Jung
Re: Ferrari F14T
Compared to this picture:
Indeed looks like they have a different exhaust..
FW17
169
Re: Ferrari F14T
There seems to be some sort of jacketing over the heat exchanger, how does the air exit out?
Dream Theater
21
Re: Ferrari F14T
I've just read that all teams will have new terminal pipes similar to this, because this is the new mandatory exaust terminal thought by the Strategy Group in order to improve the sound.
Here, the available options for the new terminal pipes:
Source: http://www.blogf1.it/2014/05/08/scarich ... no-dei-v6/
Re: Ferrari F14T
Why is that big silver shroud on the back of the radiator? Surely there must be a cut out in the back of it to exhaust the air right??
JDC123
JDC123
30
Re: Ferrari F14T
They still have a huge bypass valve to the exhaust from the turbo. Can this not be changed as you would only have one in if the MGU-H fails, so they exhaust gasses can bypass the turbine, so a reliability precaution. Now they understand the engine more, can they reduce or remove this?
trinidefender
trinidefender
317
Re: Ferrari F14T
JDC123 wrote:They still have a huge bypass valve to the exhaust from the turbo. Can this not be changed as you would only have one in if the MGU-H fails, so they exhaust gasses can bypass the turbine, so a reliability precaution. Now they understand the engine more, can they reduce or remove this?
They do this so when the mgu-h is powering the turbocharger they can bypass the turbine reducing back pressure making more power.
f300v10
f300v10
185
Re: Ferrari F14T
New rear wing with single 'goose neck' strut, and monkey seat:
Another shot, via @ScarbsF1. The wing mainplane is new as well:
And finally a clean shot via AMUS:
And from behind:
Close up view via @AlbertFabrega:
beelsebob
beelsebob
85
Re: Ferrari F14T
Looks like Ferrari (as well as Merc) are going for overhangs off the back of the side pods. I wonder if there's some benefit in managing to keep the air flow over the top of the diffuser nicely contained somehow.
muhammad-13
muhammad-13
Re: Ferrari F14T
WilliamsF1 wrote:There seems to be some sort of jacketing over the heat exchanger, how does the air exit out?
Megaphone type exhaust?
I wonder why they are covering it.
