LionKing wrote:Button was on the circuit all the time. He was on the circuit at the same time many other drivers set better times. It is not as if he missed the time when the circuit was at its best due to strategy.
I would understand what you are saying if Button was towards the front at the beginning of Q1 and others put on new tires and set better times and he was too late to do so and left out meanwhile...
Finally, I am not sure the circuit was better at the end anyway. There was heavy rain at S3....
Sorry but you really betray a lack of understanding here. When the circuit was drying the inter tyres start degrading and lose performance. By the time the circuit was at its best the grip had already gone from them. The edges of the tread get worn and lose their bite, the tread depth decreases so there isn't the movement in the rubber to generate heat and the tyres can't shift as much water, and there is thermal degradation of the rubber. It's probably not a coincidence that Vettel was slowish during the early parts of the session but then came to the fore when the conditions were perfect. That car, at least in his hands, has probably the best tyre management out there and by being slower early on then he's putting less energy into the tyre overall.
I don't claim Button would be right at the front of the field, but certainly good enough to make it through to Q2.
Edit: Had they pitted Button at the time Vettel went P1 then Button would have easily made it through. That's an operational mistake.
