Williams FW35 Renault
Richard
Richard
Re: Williams FW35 Renault
The standard axles have a nice pointy cone to guide the wheel gun onto the nut for removal and then the nut onto the axle for tightening the new wheel. So I guess there is possible risk of the wheel gun needing more care to connect as quickly.
Tim - If the cone is on the wheel gun in reverse to the current arrangement, then that would protrude beyond the nut, and that would require a recess into the wheel?
steve12345
steve12345
I think he means a small cone or shaft on the gun that will slot into the wheel blower hole? It would be inside the nut.
dunno how well it would work........oval hole and all.......I guess it would still end up in the centre of an oval.
I imagine it would have to be short/sloppy to be fast.
surely its the blower hole that is oval?
zonk
zonk
69
Do You remember this?
Ferrari 2007
steve12345
steve12345
cool - that would do the trick!
matt21
86
The Willimas wheel gun
zonk
zonk
69
It could be optical illusion, but I think on nose 2 that they are using the modesty panel to place the nose slightly higher. Nose 1 obviously is designed around the bulge under the nose. Dunno why they want to try out nose 3; surely the CoG is offset by the (marginal) aero disadvantages.
Skett
Skett
My guess would be that its an old wing and they were just testing it out for reference.
Barcelona (Session 2) - Day 1 (28.02.2013)
AMuS
Any news if they still run those fins on the exhaust bulge?
AMuS said they're gone.
tomazy
tomazy
216
Different air outlets
