2014 intercooling
232
Re: 2014 intercooling
It's the mass of conductive material.
It has more mass and surface area overall. kilogram for kilogram the above would still hold.
mrluke
mrluke
basti313 wrote:
mrluke wrote:The benefit of air to water is that you can use a smaller "charge cooler" as it is being cooled by cold water with a high SHC rather than warm air.
How can the water be cooler than the radiator in the sidepod?
I somehow get the impression, that some people think the water cooling or heatpipe cooling is like a perpetual motion machine...I put a water cooler/heatpipe on a bottle of beer and what I get is ice cold beer...
Meh, replace "cold" and "warm" with ambient. Doesn't change my post.
basti313
basti313
But you stated, that cold water gives you a smaller charge cooler than warm air. How can this point be still valid if we have water and air at ambient temperature?
Can it be, that you are still thinking about temperature peaks in the intercooling? I think they just not happen, in Malaysia the engine is 85% on throttle, 60% full throttle...Monza even 70% full throttle. There are no peaks, no time for cooling. The water stays at one temperature and the air to air cooler also stays at the same temperature if it has the same size at the cold side.
Don`t russel the hamster!
atanatizante
125
Could they build a mixture of both intercoolers in order to get the best from both?
Someone said here that one of the biggest factor in rad/intercooler efficiency (if not the biggest) is how big the specific heat value of an element/component is
Now it`s a known fact that if we are adding 3% of ordinary salt for cooking (NaCl) into 1 litre of pure water the result is the boiling point increase to 103 grade Celsius, hence the specific heat value is increasing?
Yeah, you could say now that the greater quantity of salt the greater boiling point would be but in practice the drawback is that you also increase the viscosity of the fluid …
So how about a mix intercooler with a traditional air-to-air intercooler but also has integrated in their metal walls micro or nanotubes with salty water which is running in a small and locally circuit
Jesus
basti313
basti313
atanatizante wrote:Could they build a mixture of both intercoolers in order to get the best from both?
The only benefit I can think of the water solution is that you do not have to run the charge lines through the car. But this would be still necessary with a mixture of both solutions. I do not know if there is such a solution anywhere in practice.
atanatizante wrote: Someone said here that one of the biggest factor in rad/intercooler efficiency (if not the biggest) is how big the specific heat value of an element/component is
No. The heat capacity always only goes into the Prandtl number http://en.wikipedia.org/wiki/Prandtl_number
And the Prandtl number only goes into the process with ^0.4 whereas the flow rate of the fluid goes into it with ^0.8 (very basic assumptions, not really going into details). So you do not have to concern about changing the heat capacity at all as it is easily covered by changes in the flow rate.
atanatizante wrote: Now it`s a known fact that if we are adding 3% of ordinary salt for cooking (NaCl) into 1 litre of pure water the result is the boiling point increase to 103 grade Celsius, hence the specific heat value is increasing?
It is the other way round. Adding salt/alcohol to water decreases the specific heat as it destroys hydrogen bonds and, thus reduces the thermal conductivity.
atanatizante wrote: So how about a mix intercooler with a traditional air-to-air intercooler but also has integrated in their metal walls micro or nanotubes with salty water which is running in a small and locally circuit
There is no need to store the heat in water as there is no time for cooling it away.
mrluke
mrluke
basti313 wrote: But you stated, that cold water gives you a smaller charge cooler than warm air. How can this point be still valid if we have water and air at ambient temperature?
No. its because the water has a much higher shc so can absorb more temperature from a smaller exchange area.
The reason my wording got jumbled up was that the water will be cold in comparison to the compressed air, but the outside air temperature is unlikely to be described as cold, I should have reread and corrected.
232
At the end of the day it's the air passing through and out the sidepod.
That air can take only so much heat when it comes into contact with the heat exchanger, regardless of what's in it.
You want that exchange to be as efficient as possible.
Abarth
45
Exactly. And you want the temp difference between outside air and the medium which has to be cooled as high as possible, as cooling power raises with raising delta T.
And this has its limits, obviously.
232
hmm i'm not seeing where a water intercooler would would be in this case..
There doesn't seem to be any room for one, if we look on where the air intakes split around the air filter.
232
Here we see Mclaren with their intercooler on the left hand side of the car.
I think the black pipe on top is the charge air pipe.
The right hand side only has one heat exchanger.
I guess the weight of the air in the intercooller wont make the car too unbalanced laterally.
Owen.C93
Owen.C93
177
ringo wrote:http://www.autobild.de/ir_img/1/1/6/6/6 ... 90d826.jpg
http://img3.auto-motor-und-sport.de/Mer ... 769432.jpg
I'm fairly sure it's down between the fuel tank. There's no need to put it in the sidepod like Lotus because the compressor is at the front already.
http://www.f1technical.net/forum/viewto ... 82#p495182
Having since seen the long and thin lotus cooler then perhaps that black pipe I put the red arrow on is the cooler itself and it may not be a big cube one like Ferrari.
Owen.C93
Owen.C93
177
ringo wrote:Here we see Mclaren with their intercooler on the left hand side of the car.
http://img4.auto-motor-und-sport.de/McL ... 769268.jpg
https://pbs.twimg.com/media/BimJqCQCIAAOGtG.jpg:large
Looking at the images the intercooler looks to be on the bottom pic by the shape of the cooler pipe entry on top.
timbo
timbo
113
I think the intercooler is on the left side of the car.
FW17
171
If merc are running water air intercooler, they could be running with the heat exchanger within the intake plenum
but this pic is confusing
mrluke
mrluke
I am wondering if the compressor has 2 outlets, one hidden behind the fuel cell. This would allow 2 charge air coolers serving as part of the pipework and linking the compressor outlet with the carbon intake manifolds.
That last picture is interesting though, looks like a torturous route for the charge air.
