Alpine A521
Re: Alpine A521
GoranF1 wrote:
14 Mar 2021, 18:44
Livery and Reliability very good. Question marks over pace and speed.
Well we knew going in that they were throwing limited resources at 2021.
Re: Alpine A521
cheeRS wrote:
14 Mar 2021, 20:24
outer_bongolia wrote:
14 Mar 2021, 20:15
Blackout wrote:
13 Mar 2021, 10:27
They are running the shorter roll hoop cover today + the smaller hot air exits at the back of the car
https://i.imgur.com/6oLkfVF.jpg
Wow. Comparing these pictures, Ocon looks like he’s sitting a lot higher than Alonso. I wonder what it does to the air coming in from the lower inlet.
He sure does! Wonder how that effects the protection from the halo 😳
Yikes! That's really exposed! They might have to use my invention, the High Halo for Ocon.
Re: Alpine A521
Interestingly, Ocon said in his helmet presentation video that "we need no spoilers anymore this year"
And inded, both drivers ditched the helmet rear spoiler https://i.imgur.com/6oLkfVF.jpg
https://twitter.com/AlpineF1Team/status/1367068575203221505
--> this might be a clue: the helmet needs no spoiler because the lower air intake behind the helmet needs/worsks with a different airflow in 2021?
OCO and RIC: different helmet and height -- > different spoilers in 2020
They've tested this special spoiler on the drivers helmet + this winglet in 2018 where this rollhoop design first appeared...
But they didnt keep them
shady
shady
Re: Alpine A521
PlatinumZealot wrote:
03 Mar 2021, 01:46
shady wrote:
03 Mar 2021, 00:06
MtthsMlw wrote:
02 Mar 2021, 17:43
Interesting slotted cape
https://i.imgur.com/yweHBLD.jpg
The cape isnt slotted, thats an optical illusion.
The outer edge of the cape is lower than the 'mainplane' of the cape, it falls off a bit. the white lights above make that transition look like a slot. In addition, there are vertical strakes on the cape as well, they look almost like hooks, they are just flow conditioners, the combination of these plus the angle make it look like a slot.
Remove your shades.
So about those slots...???
Re: Alpine A521
And the adding of these new air inlets inside the lower roll hoop duct, which has been remodeled as well IMO, is quite intriguing...
It seems the walls of the lower duct do not diverge/expand anymore.... so it is possible that the lower intake does not serve for CCS cooling anymore (or far less than before) and that it feeds the compressor instead... :idea:
EDIT: it still looks too big for the compressor... so I bet it's divided between compressor air supply and cooling...
Re: Alpine A521
shady wrote:
14 Mar 2021, 22:57
03 Mar 2021, 01:46
shady wrote:
03 Mar 2021, 00:06
Remove your shades.
Hmm nothing has changed from when I said I wait till a few races. Sometimes the CG images usually have parts that are being considered for future races.
What i use to identify the slot is the presence of the little brackets. If it weren't slotted unlikely brackets would be needed there.
Re: Alpine A521
Blackout wrote:
14 Mar 2021, 22:57
https://i.imgur.com/i3Q0Izq.jpg
https://storify.com/services/proxy/2/VZ ... 9I8713.jpg
You can watch where the mechanics stick the dry ice blowers when they bring the car into the garage.
Re: Alpine A521
15 Mar 2021, 03:33
Blackout wrote:
14 Mar 2021, 22:57
I tried :lol: but thy stick them in both intakes :mrgreen:
Re: Alpine A521
bucker wrote:
14 Mar 2021, 17:27
TimmTurbo wrote:
14 Mar 2021, 17:09
Man that car looks ugly.... the airbox is out of any proportion. No wonder why nobody wants to get that PU
Because PU is reason for bulkier look....
Exactly...
Mclaren had the exact same engine in 2020 and despite that they had a much thinner rollhoop... (AND more undercut sidepods)
The bodyworks had different widths simply because the positioning of the 'CCS' coolers inside was different.
The Renault had/have a wider radiator placed further forward just above the engine so it must be inserted between the compressor duct (blue) and the engine, and sit in a more flat position (about 30°) and go wide, while the other CCS (except the Mercedes teams) are positioned at 60°-70° further back and can go long and thin...
RP/Williams and Mercedes*
Re: Alpine A521
Tooooom
Tooooom
Re: Alpine A521
Blackout wrote:
15 Mar 2021, 13:29
bucker wrote:
14 Mar 2021, 17:27
TimmTurbo wrote:
14 Mar 2021, 17:09
Exactly...
https://i.imgur.com/wqdKpfx.jpg
Merc
https://i.imgur.com/3eeRvVO.jpg
Amazing, thank you for these illustrations!
Re: Alpine A521
The very exposed boat-tail area under the gearbox
Tooooom
Tooooom
Re: Alpine A521
Do other cars have that part exposed as well?
Edit: My bad, I didn't know these parts were separated for all cars, I always thought they were joined.
Re: Alpine A521
Blackout wrote:
15 Mar 2021, 16:37
https://pbs.twimg.com/media/EwczLD2WgAA ... ame=medium
I like what they've done there....
The way the exhaust points down will really energize the diffuser air.
Re: Alpine A521
Tooooom wrote:
15 Mar 2021, 17:49
Some look very exposed (RB, Alpine, MCL, Ferrari), so some seem to be less exposed...
viewtopic.php?p=956767#p956767
